Problem with Propeller BOE reset
Last weekend I bought a new Propeller BOE from a local store (Micro Center) with the intention of replacing the original basic stamp BOE. Since I was not familiar with the Propellor, I followed the initial training information on the learn.parallax.com site. I ran into problems when I started trying to run the Test Full Speeds spin code:
OBJ
system : "Propeller Board of Education"
servo : "PropBOE Servos"
time : "Timing"
PUB Go | i
system.Clock(80_000_000)
servo.Set(14, 200)
servo.Set(15, -200)
time.Pause(3000)
servo.Set(14, -200)
servo.Set(15, 200)
time.Pause(3000)
servo.Set(14, 0)
servo.Set(15, 0
When I run the above program, the Prop BOE seems to execute only the first two servo statements and the pause, then it resets and repeats the first two servo sets and the pause then resets......indefinitely. This occurs with the the Prop BOE pwr switch is in position #2.
If I add the following code (with references to the pin object)
pin.High(9)
time.pause(200)
pin.Low(9)
time.pause(200)
to the end of the program and run it with the pwr switch in position #1, the program runs till completion and pin 9 lites after approximately 6 seconds (the delay). It does not appear to reset in this case
I suspect that something is defective with the board but is there way to perform a definitive test? If anyone out there has any ideas it would be appreciated.
OBJ
time : "Timing"
PUB Go | i
servo.Set(14, 200)
servo.Set(15, -200)
time.Pause(3000)
servo.Set(14, -200)
servo.Set(15, 200)
time.Pause(3000)
servo.Set(14, 0)
servo.Set(15, 0
pin.High(9)
time.pause(200)
pin.Low(9)
time.pause(200)
I performed two additional tests this afternoon.
Removing one servo connection and running the same program causes the second set of servo commands to be executed and the program appears to terminate (since the led flashes). However the servo never stops after executing the second set of servo set instructions.
I have moved the server connections to all of the servo pins 14-19 and I have used servos from two other BOE Bots. All have exactly the same effect.
What am I missing?
I guess i know where I will be buying my batteries from now on! Sorry to bother you guys.
One final thing... Should I be able to run the drive servos and a ping sensor servo off of the same set of batteries or should I look to a different power solution?
Thanks again
One problem I've found when using four NiMH AA cells is the voltage can drop over time making navigation difficult.
With my CheapBot, I used four Li-Ion AA and a 5V regulator so the servo speed would be consistent from one run to the next. I'd think the regulator on the PropBOE might take care of the voltage regulation for you but I still think four NiMH AA cells is on the low end of acceptable power for your robot.
Servos can draw up to 1A or so when starting up or under heavy load. 2A is a big load for AA batteries even though the current drops quickly as the motors begin to move. Parallax's LiIon Pack is great and mounts (tightly) in the space under the BoeBot in place of the standard 4-cell holder. I recommend it, particularly if you're going to use your BoeBot a lot.
The Propeller BOE is designed to be able to supply two servos at least in addition to the circuitry on the board. Normally, when you add a PING))) and its servo bracket, the PING is not used at the same time as the wheels because you don't want the BoeBot to be moving significantly while you're trying to measure distance, so the current drain is that for two servos at a time plus the BOE.
A bit more voltage, current and capacity will make your robot projects so much easier. These servos can pull up to a half-amp if you've got two drive servos and one for the Ping))). And the Ping))) can be a bit of a pig as well. Just stuff the system with power and put this problem behind you.
That's my suggestion.
There's a whole lot of great stuff in store for Propeller Boe-Bot owners in the future. Can't say more. . .
A simple sanity check for Suspect-Power issues, is to run TWO battery packs :
One powers just the CPU, and the other powers the Motors.
If that gives a large difference and a clean-up in behaviour, you know it it Load/Vcc interactions.
I had similar problems with batteries. To make things better I asked from a local shop to make for me a pack from 6X1.2 v researchable batteries. I asked them to arrange the batteries in appropriate way in order to fit perfect on Prop boe’s chassis. (as you can see I have made a “Π” holder in order to adapt the pack into the chassis.
On the existed hole of the chassis I also added a small on off switch. For the charging I don’t remove the pack from the robot. I use a charger and a homemade connector in order to connect the batteries pack’s cable with the charger.
Edit: I'm looking forward to see what Ken has made for us with the news accessories for the Propeller Boe-Bot!
