Does anyone know of a good IR Remote OBEX that works something like the Stamp version? Also, do I set up the IR receiver in the same fashion on the Prop BOE as a Stamp BOE?
Thanks. That is what I needed. Is there a schematic somewhere that I can follow? I do not want to have to take Ken up on his Lifetime Warranty for the Prop BOE!!!!!
NW here is an example of how to use the program I posted, this will show the button your pressing on the remote on the serial terminal. 255 if no button is pressed.
CON
_CLKMODE = XTAL1 + PLL16X
_XINFREQ = 5_000_000
IRPIN = 0 'output of ir receiver
Obj
pst : "parallax serial terminal"
ir : "irtest"
Var
long ircode
Pub main
pst.start(115200)
ir.start(IRPIN, @ircode)
repeat
pst.char(1)
pst.dec(ircode)
Jeff
I use TSOP4838 with all my products. They will run at between 2.7v and 5v, so they are very safe for your PropBOE.
Jeff
Jeff
