HDTV Signalling — Parallax Forums
HDTV Signalling
cgraceycgracey Posts: 14,286
edited 2013-03-10 14:13 in Propeller 2
Since the Prop2 can generate HDTV signals in Y/Pb/Pr component format, I thought I'd share a link to the document covering HDTV signal generation. I offer this because it is almost impossible to find if you don't know what to ask for. I haven't tried recently, but when I started doing work to support HDTV, I could not find anything that described the signal format from many, many searches. Somehow, after much time, I discovered that what I needed to know was in "RECOMMENDATION ITU-R BT.709-3". It's all here:
http://www.itu.int/rec/R-REC-BT.709-5-200204-I/en
I will post some Prop2 code here soon that does 1080p video generation. It just takes three pins on the Prop2 configured as DACs. The output signals are called Y (luma), Pb (blue difference), and Pr (red difference). These are typically connected via RCA (or phono) cables.
«13
  • SapiehaSapieha Posts: 2,964
    edited 2013-02-20 17:08
    Hi Chip.
    Can you even post NTSC and PAL configurations and examples ?.
  • cgraceycgracey Posts: 14,286
    edited 2013-02-20 18:17
    Here is an HDTV 1920x1080p luma bars example on the DE0-Nano:
    ''*  HDTV 1920x1080p  *
    ' P3 = Y
    ' P2 = Pb
    ' P1 = Pr
    CON
      _clkmode = xinput
      _xinfreq = 60_000_000
      s = 43	'scales DAC output (s = 0..128)
    DAT		org
    		reps	#256,#4			'start 8-bit incrementing sequence at $BB
    		setspa	#$BB
    		incmod	x,#63		wc
    	if_c	mov	luma,lumas
    		pusha	luma
    		add	luma,lumad
    		setctra	#%00111			'set ctra for PLL*8
                    setfrqa	frqa_			'set frqa
    		setvid	#%0110			'set vid for hdtv output
    		setvidy	vidy_			'set yiq coefficients
    		setvidi	vidi_
    		setvidq	vidq_
    		cfgdacs	#%11_11_11_00		'set top three dacs to video mode (Y/Pb/Pr)
    		cfgpins	pinmask,pindacs		'set pins for dac outputs
    ' Field loop
    field           mov	x,#36			'top blanks
    		call	#blank
                    mov     y,lines_vis		'set visible lines
    line	        call	#sync			'do horizontal sync
    		waitvid	v60,sync_color1		'porch
    		waitvid	mode,#0			'256 pixels per waitvid
    		djnz    y,#line           	'another tile line?
                    mov     x,#4			'bottom blanks
    		call	#blank
    		mov	x,#10			'low vertical syncs
    vsyncl		call	#sync
    		waitvid	v880,sync_color2
    		djnz	x,#vsyncl
    		mov	x,#10			'high vertical syncs
    vsynch		call	#sync
    		waitvid	v880,sync_color1
    		djnz	x,#vsynch
                    jmp     #field                  'field loop
    blank		call	#sync			'blank lines
    		waitvid	v1980,sync_color1
    		djnz	x,#blank
    blank_ret	ret
    sync		waitvid	v44,sync_color1		'horizontal sync
    sync_ret	retd
    		waitvid	v44,sync_color2
    		waitvid	v44,sync_color3
    		waitvid	v88,sync_color1
    ' Initialized data
    luma		long	$03020100
    lumas		long	$03020100
    lumad		long	$04040404
    frqa_		long	$4F33_3333		'148.5 MHz
    vidy_		long	 80 << 24 + ((+27*s/128) & $FF) << 16 + ((+92*s/128) & $FF) << 8 + (( +9*s/128) & $FF)
    vidi_		long	128 << 24 + ((-15*s/128) & $FF) << 16 + ((-49*s/128) & $FF) << 8 + ((+64*s/128) & $FF)
    vidq_		long	128 << 24 + ((+64*s/128) & $FF) << 16 + ((-58*s/128) & $FF) << 8 + (( -6*s/128) & $FF)
    pinmask		long	%1110			'pin mask for P3..P1
    pindacs		long	%1111_101100000		'pin configuration for video DAC
    		'	color base	mode		clocks/pixel	clocks/waitvid
    mode		long	$BB << 24 +	$A << 20 +	5 << 13 +	1920
    lines_vis	long	1080
    sync_color1	long	$1_000000
    sync_color2	long	$1_E00000 | ((-105*s/128) & $FF)	'sync- on all three outputs
    sync_color3	long	$1_E00000 | ((+105*s/128) & $FF)	'sync+ on all three outputs
    v44		long	44
    v88		long	88
    v880		long	880
    v60		long	60
    v1920		long	1920
    v1980		long	1980
    x		long	0
    y		long	0
    The R-2R DACs are imperfect on the FPGA boards, so you see some lines. The Prop2 chip should be perfectly smooth.
    I'll try to post an NTSC example tonight.
    500 x 375 - 127K
  • jmgjmg Posts: 15,194
    edited 2013-02-20 19:12
    Since the Prop2 can generate HDTV signals in Y/Pb/Pr component format...
    Y-Pb-Pr is a good way to simply avoid Chroma carrier effects, but it is something of a fading standard.
    Finding displays with Y-Pb-Pr is getting harder and harder, as everything moves away.
    It seems the Chip-Sets do support VGA => LCD and Y-Pb-Pr => LCD, but the Y-Pb-Pr is seldom implemented, due to connector size/cost ?
    The poorer quality Chroma carrier (PAL/NTSC) displays seem to have life in them, as Camera displays in Backing Cameras etc
    I did notice some Chinese vendors offering VGA signals, but using a Mini-USB cable - an interesting way to side-step connector bulk.
    Not sure if that idea will hit critical mass, but they could do the same thing for Y-Pb-Pr
    edited 2013-02-20 20:04
    Brand new model HDTVs seem to all still have component input (Y/Pb/Pr), not sure why you think it's fading? Many of them still have composite input too.
    I just browsed through models from every brand of HDTV on newegg, and didn't find any without component in. Even the newest models that just came out.
    Even the new 4k res TVs from Sony and others have component inputs. So, really, no idea at all why you think it's going away...
  • tonyp12tonyp12 Posts: 1,951
    edited 2013-02-20 20:17
    Items that have 3 phone (Y/Pb/Pr) coming out from them is disappearing.
    But Prop2 pcb designers could go the Roku way too.
    edited 2013-02-20 20:55
    Roy Eltham wrote: »
    At the very high end / large screen sure, but how many projects want to connect to a 40" TV ?
    I can find only one unit, under 10" that mentions Y-Pb-Pr, and below 32", they seem to be thin, with HDMI easily dominating.
    edited 2013-02-20 22:05
    jmg wrote: »
    Do you have a link? I am interested in the pinout and if the cable is available cheaply - would solve a lot of size problems.
    edited 2013-02-20 23:36
    I found this component cable, which hooks into a VGA connector:
    This is kind of nice, because you have VGA, anyway, and if you want to do HDTV, just use this cable and change the video generation. No need for HSYNC or VSYNC signals - only R, G, B.
    450 x 450 - 27K
    edited 2013-02-20 23:38
    edited 2013-02-20 23:48
    Cluso99 wrote: »
    I only have a 'ended' ebay listing link, but you can see the Mini-usb-VGA cable etc
    http://www.ebay.com.au/itm/7-LCD-Color-TV-AV-VGA-Car-Rearview-16-9-Monitor-/170631583602?pt=US_Rear_View_Monitors_Cams_Kits&hash=item27ba6f5772
    I thought it was a good idea, but hard to guage if it hit 'critical mass' ?
  • Ym2413aYm2413a Posts: 630
    edited 2013-02-21 05:37
    This is neat!
    Hope to see the NTSC example soon. : ]
    edited 2013-02-21 08:49
    Thanks for the document Chip.
    edited 2013-02-21 09:17
    this is getting very interesting
    edited 2013-02-21 09:29
    Yeah, can't wait for a DAC board.
    Re: YCbCr
    This input standard is popular with people who do high end home theater. Most mid and large sized displays will have them where they don't always have RGB.
    I personally like it because a monochrome signal just requires one connection. The "Y" input for this format literally displays anything you throw at it from ordinary NTSC TV video to HDTV 1080i or p.
    One thing I plan to try, and I almost did this with P1, is to run detail at high resolution, color differences at a more modest one for the illusion of HD, but not really. Sort of a play on what NTSC does, only without so many ugly artifacts.
    Could run the monochrome signal at say 640x400, and the two color differences at 160x200 for example. :)
    edited 2013-02-21 09:59
    Thanks Chip.
    Everyone:
    it is easy to find 15"+ HDTV's with component video input here in Canada, and I suspect the same is true in the states.
    Search for TV's, NOT monitors. BestBuy, Costco, Newegg, TigerDirect etc should all have quite a selection.
    edited 2013-02-21 18:51
    jmg wrote: »
    Unfortunately its not a miniUSB! If I had thought about it properly, you need 6 pins for VGA (R,G,B,HS,VS,GND). I am always on the lookout for a simple/easy/cheap way to use a miniature connector for VGA.
    Chip: Those AV cables to video/stereo are available on eBay for about $1-2 shipped. Be careful of the pinout as there are two common variants, the AV (video cameras and Nokia phones) and the Apple variant (third pin is ground instead of fourth with first pin being the tip).
  • CircuitsoftCircuitsoft Posts: 1,166
    edited 2013-02-21 21:29
    It is MiniUSB. R,G,B,HS,VS can be on the 5 pins, and ground can just use the shell. Does mean you won't get I2C/DDC, though.
    edited 2013-02-21 21:31
    It looks like mini USB to me. They must be cheating and using the shield as the 6th conductor for GND.
    edited 2013-02-21 22:12
    That was my conclusion.
    Of course, what would make this appealing, is not so much the connections, as the molded cable-set, if it comes at the right price.
    Clearly some are being made. Not sure on the volumes tho.
    I did find this [MiniUSB To VGA Cable] : (US $5.98 FREE - Economy Int'l Shipping ex China )
    http://www.ebay.com.au/itm/Mini-USB-Male-5-pin-To-VGA-D-SUB-15-pins-Male-Adapter-Cable-For-Mobile-DVD-EVD-/281067703428?pt=LH_DefaultDomain_0&hash=item4170f0cc84
    edited 2013-02-22 02:20
    Here's the NTSC example (sorry for the poor picture):
    You can see here that the Prop2's video modulators generate sinusoidal signals, not square waves. This works much better, along with real RGB source colorspace remapped to whatever you need:
    Here is the program:
    ''*  NTSC 256x192  *
    ' P0 = YIQ
    CON
      _clkmode = xinput
      s		= 46		'scales DAC output (s = 0..128)
      r		= s * 78 / 128	'adjusts for modulator expansion
      lntsc         = 3640          'NTSC colorburst cycles per line * 16
      sntsc         = 624           'NTSC colorburst cycles per sync * 16
    DAT		org
    		reps	#64,#2			'start 8-bit incrementing sequence at $BB
    		setspa	#$BB
    		pusha	luma
    		add	luma,lumad
    		setvid	#%1110			'set vid for composite output
    		setvidi	vidi_
    		setvidq	vidq_
    		cfgdac0	#%11			'set bottom dac to video mode (YIQ)
    		cfgpins	pinmask,pindacs		'set P0 for dac output
    ' Field loop
    field           mov	x,#34			'top blanks
    		call	#blank
                    mov     x,#192			'set visible lines
    line	        call	#hsync			'do horizontal sync
    		waitvid	v_bo,#0			'black left border
    		waitvid	mode,#0			'256*9 clocks per waitvid
    		waitvid	v_bo,#0			'black right border
    		djnz    x,#line           	'another line?
                    mov     x,#28			'bottom blanks
    		call	#blank
    		mov	x,#6			'high vertical syncs
    		call	#vsynch
    		mov	x,#6			'low vertical syncs
    		call	#vsyncl
    		call	#vsynch
    blank		call	#hsync			'blank lines
    		waitvid	v_bl,#0
    		djnz	x,#blank
    blank_ret	ret
    hsync		waitvid	v_bs,c_sh		'horizontal sync
    		waitvid	v_sn,c_sl
    hsync_ret	retd
    		waitvid	v_bc,c_sh
    		waitvid	v_cb,c_cb
    		waitvid	v_bv,c_sh
    vsynch		waitvid	v_bs,c_sh		'vertical sync high
    		waitvid	v_hs,c_sl
    		waitvid	v_hr,c_sh
    		djnz	x,#vsynch
    vsynch_ret	ret
    vsyncl		waitvid	v_bs,c_sh		'vertical sync low
    		waitvid	v_ls,c_sl
    		waitvid	v_lr,c_sh
    		djnz	x,#vsyncl
    vsyncl_ret	ret
    ' Initialized data
    luma		long	$03020100
    frqa_		long	$1E8B_A2A7		'57.272720 MHz (colorburst * 16)
    vidy_		long	(110*s/128 & $FF) << 24 + ((+38*s/128) & $FF) << 16 + ((+75*s/128) & $FF) << 8 + ((+15*s/128) & $FF)
    vidi_		long	(100*s/128 & $FF) << 24 + ((+76*r/128) & $FF) << 16 + ((-35*r/128) & $FF) << 8 + ((-41*r/128) & $FF)
    vidq_		long	              128 << 24 + ((+27*r/128) & $FF) << 16 + ((-67*r/128) & $FF) << 8 + ((+40*r/128) & $FF)
    pinmask		long	%1			'pin mask for P0
    mode		long	$BB << 24 +	$A << 20 +	9 << 13 +	256*9
    v_bo		long	(lntsc-sntsc-256*9)/2	'left/right border
    v_bs		long	100			'before sync		horizontal sync
    v_sn		long	269			'sync
    v_bc		long	50			'before colorburst
    v_cb		long	144			'colorburst
    v_bv		long	sntsc-144-50-269-100	'before visible
    v_hs		long	135			'high sync		high vertical sync
    v_hr		long	lntsc/2-135-100		'high sync remainder
    v_ls		long	1564			'low sync		low vertical sync
    v_lr		long	lntsc/2-1564-100	'low sync remainder
    v_bl		long	lntsc-sntsc		'blank visible
    c_sh		long	$1_000000		'sync high
    c_sl		long	$2_000000		'sync low
    c_cb		long	$1_707000		'colorburst reference color
    x		long	0
    529 x 459 - 148K
    811 x 675 - 206K
    edited 2013-02-22 02:30
    Hi Chip.
    edited 2013-02-22 09:06
    DVI/HMDI would open up a hole new market.
    Minimum clock frequency: 25.175 MHz *10bits = 251.75 mhz serializer needed.
    I guess is no way to get that, even if using 2-4 cogs.
    edited 2013-02-22 09:21
    tonyp12 wrote: »
    You could push the video shifter to 251.75 MHz. Bit I think there is some NRZ encoding needed, too.
    edited 2013-02-22 09:29
    Maybe the LUT could be used as a lookup table for these 8bit to 10bit conversions.
    And to simplify I think of not using accumulator error handling that keeps track of accumulator errors of 0 or 1 in majority so far.
    As normally there are 460 combinations for representing an 8-bit data value, as most of the 256 possible values have two encoded variants (some values have only one),
    Though the differential data out is at 251.75mhz, the clock-out is still at 25.175mhz.
    And if we could put a hdmi connector on a Prop2 pcb, we could use it both for dvi and vga with this cable.
    http://www.aliexpress.com/item/1Pcs-HDMI-Gold-Male-to-VGA-HD-15-Cable-6ft-1-8M-Free-shipping-Drop-ship/291350570.html
    or hdmi to component
    http://www.aliexpress.com/item/12-PCS-HDTV-1080P-5FT-HDMI-to-3-RCA-Male-Audio-Video-Component-Convert-Cable-1/662763196.html
    or hdmi to vga+video+audio
    http://www.aliexpress.com/item/HDMI-HDTV-to-VGA-3-RCA-Converter-Adapter-Cable-1080p/680356214.html
    edited 2013-02-22 10:26
    Thanks for the example Chip!
    Looks great!
    edited 2013-02-22 12:53
    Could HDMI be driven with something like a TFP410? That would take 27 I/O lines. Maybe an LVDS receiver could be used to reduce pin count? Or, just a regular serial-to-parallel shift register?
    edited 2013-02-22 13:25
    To reduce pin count a fast lvds driver could reduce from 8pin to 4pins for dvi and also useful if Prop2 serilizer can not do differential output.
    http://www.mouser.com/ProductDetail/Texas-Instruments/DS90LV031ATMX-NOPB/?qs=sGAEpiMZZMtTXF9i0pOGl%2fbsaGN3nQrHlCzttN70mc8%3d
    But using something like a TPF410 is a pin waster and so prop1 and also costly.
    edited 2013-02-22 13:42
    HDMI would probably be too much trouble on the Prop2, no matter how it was approached. We've got good analog outputs, though, that take just three pins for HDTV. I think putting a VGA connector on your board, wired for VGA output, and then using a VGA-to-component cable for HDTV is the way to go. Add a phono jack for composite, and you've got every analog format covered (except 5-pin S-Video, but that connector doesn't seem to be on new equipment). All these big TV's seem to have a VGA connector, anyway, so maybe component video is not even that important. There's nothing cleaner than straight VGA R-G-B signaling.
    Look at this 50" 1080P TV from Newegg for $399. Pretty amazing how cheap things are becoming: http://www.newegg.com/Product/Product.aspx?Item=N82E16889112066&cm_sp=DailyDeal-_-89-112-066-_-Homepage
  • pedwardpedward Posts: 1,642
    edited 2013-02-22 15:14
    I remember discussing DVI with Chip a while back. You need 139Mhz clocking to do HTDV, which translates to several Gigabits per second. The TPF410 is the best option, or a hybrid of ADC to TFP410. Special purpose chips to do video conversion cost almost twice what the P2 chip will cost.
    edited 2013-02-22 15:59
    Not having to use anything else to do 480P over hdmi would be great.
    If you want 1080i/p over hdmi, these converter IC from NXP are in the $5 range.
    http://www.mouser.com/Search/Refine.aspx?Keyword=TDA998
