Propforth 5.0 is available for download - Page 16 — Parallax Forums
1101112131416»
  • caskazcaskaz Posts: 957
    edited 2013-02-16 19:06
    It goes round.
    A little more bit until walking, maybe.
    http://youtu.be/YULzrPPwDPY
    edited 2013-02-19 21:45
    Hi.
    I'm learning Logic mode for counter.
    : test
    h18000000 d10 + ctra COG!   \ DUTY single-ended
    d10 pinout
    d80000 frqa COG!
    0 phsa COG!
    h68000000 d10 + ctrb COG!     \ LOGIC A
    1 frqb COG!
    d1000  negate phsb COG!    cnt COG@
    \    begin  phsa COG@ . phsb COG@ . cr fkey? swap drop until
    begin phsb COG@ 0> until
    cnt COG@ swap -  d80000 u/  .
    I expected 1000(decimal).
    But,result was 671(decimal).
    Where is wrong?
    edited 2013-02-19 22:56
    caskaz wrote: »
    Where is wrong?
    Code looks OK from a quick glance. That said, depending on cog/pin setup DUTY mode doesn't go down too well with LOGIC modes (I've seen everything from 0..2 events for a single pulse @80MHz). Running at e.g. 40MHz usually makes it work. If you need to chain counters at 80MHz you're better off using edge detection.
    edited 2013-02-20 05:19
    Hi.
    Kuroneko-san, Thanks.
    Mistake is constant of frqa.
    : test
    d10 pinout
    d53686 frqa COG!  <----- d80000 is incorrect
    \ 0 phsa COG!        <----- Not need
    1 frqb COG!
    Result is d1001(1second).
    edited 2013-02-22 01:00
    Hi.
    I'm making Data-Logger by using P-10 Tester.
    Previous post is #396.
    Now, only resistor.
    Next step;
    Adding Current and Voltage.
    Saving data to SD-card(FAT)
    http://youtu.be/IflvQnQUKlw
    edited 2013-02-24 20:28
    Today's Call
    Sal has started final scrub of the issues list
    http://code.google.com/p/propforth/issues/list
    We're down to 11 open issues, and four of them are just enhancements; so only seven to go. These only need the documentation completed as all the corrections and changes were made and verified long ago.
    The final challenge is presenting the package so newcomers can find what they need (the kernel), and yet still maintain a complete development package (the full build and test automation). While most of us simply "load the kernel", Sal mostly crafts a custom kernel for whatever hardware he's faced with, and add this to his regression suite. Since the tool is designed for the most advanced user, it can be a little much for the rest of us. With the proper changes, we think we can keep it very simple, and include the advanced material in the package without it being "in the way".
    I'm pretty lucky that Sal tollerates my requests for user friendly, n00b oriented packaging and presentation. While he does find some benefit to this (its more uniform and documented than if it were simply a personal tool) it takes significant time and effort on Sal's part.
    VGA has finally been brought forward to 5.x! Hurray! This fulfils my original goal when I bought my first Prop Demo board five yeas ago, and then some. Finally, I may have a fully functional, optimized, self hosting forth system on my prop. I still have to test it this week, but being an extension, its just load and make sure it goes for now.
    edited 2013-02-25 18:52
    Hi.
    Bot walked.
    But I understand this walking is incomplete because 1-leg have 2-servo.
    So, I gave up to write codes for this bot(KMR-P4).
    I will build up another bot(3 servo-motors per 1-leg).
    http://youtu.be/nEF8up5XXMQ
  • KC_RobKC_Rob Posts: 465
    edited 2013-02-27 09:32
    All this thoughtfulness and hard work is certainly appreciated. I experimented (er, played) with PropForth again yesterday, and have to say that I'm impressed. It just works. I like the fact that it's reasonably close to "conventional" Forth ("Starting Forth", "The Complete Forth", etc.) so that neophytes such as myself can take knowledge gleaned from traditional sources, along with the PropForth documentation, of which there's a decent amount now, and jump right in. Kudos! :)
    edited 2013-03-02 05:51
    Hi.
    I had got GraphicLCD(WD-G2406B).
    I can't find out this LCD's manual.
    But I got pdf-files for driverIC(T6A39 and T6A40).
    I made a picture of curcuit diagram between terminal and driverICs.
    1024 x 726 - 81K
    1024 x 768 - 88K
    1024 x 768 - 55K
    edited 2013-03-04 21:50
    Hi.
    Displayed ROM-Font to GraohicLCD.
    1024 x 768 - 50K
    edited 2013-03-07 22:28
    edited 2013-03-10 12:39
    today's call
    PropForth v5.5 is configured to include five kernels in the default download:
    1. PropForth: simple propforth Development Kernel. Dev Kerenel is optimized in assembler and includes typical development tools.
    2. PropForthEEprom: EEPROM File System kernel. The Dev Kernel with support to write and read 'files' in upper EEPROM (above 32k).
    3. PropForthSD: SD File system kernel. Dev kernel with support to write and read 'files' on SD card.
    4. PropForthIP: Dev kernel with IP support. This is for Spinneret
    5. PopforthEEpropIP: EEprom dev kernel with IP suppot for Spinneret.
    Most folks will use the simple Dev kernel. Advanced folks will use either the EEprom or SD file system kernels. Only a few folks (that we know of) will generate custom kernels. Therefore the build and test automation, and custom kernel support has been moved to reduce confusion.
    Notes:
    • The kernel criterion is STOCK parallax items, such as quickstart, protoboard, demoboard, and spinneret
    • All the default dev kernels will include the developer support as in the Propforth Dev kernel.
    • The EEpropm kernel will work on any standard propeller board that has 64K or greater EEprom. This means everything except the Demoboard.
    • 'File' means contiguous 512 byte pages. The EEprom and the SD cards both use 512 byte pages. The next 'file' starts at the next unallocated page, and continues for as many pages as allocated. The last file may be de-allocated, or the whole device may be re-initialized
    • pages can be modified/overwritten, but are never deleted, as they are physical locations.
    • The SD material is 'stock' by way of the spinneret.
    • The IP material is 'stock' by way of the spinneret, but can be problematic due to configuring the rest of the network. Anyone that understands router configuration should have no trouble with it. Everyone else should consider the easier alternatives.
    • The custom kernel build and test automation has been moved to the MISC subdirectory. Its still included, but out of the way so folks don't stumble on it until they actively look for it.
    • HTTP support has been removed from the default kernels. It is still present in the custom kernels section.
    • The kernel with both SD and EEprom files system support has been removed from the default kernels as unneeded.
  • TrapperBobTrapperBob Posts: 148
    edited 2013-03-12 04:14
    When will be the next "official" relase of Propforth? I see lots of v5.3 listed in docs and now v5.5 . What version will be released?
    edited 2013-03-17 09:41
    Right NOW!
    Please notice - v5.0 is no longer the current release. Please see thread http://forums.parallax.com/showthread.php/146693-Propforth-v5.5-is-available-for-download
    edited 2013-03-17 10:07
    YAY!!!! ...and I mean that in a GOOD way!!! :lol:
    Onward to the FUTURE!
