12v to 9.5 converter
Hi all
I have a converter that reduces a rechargable 12v lead acid battery to 9.5v dc, I need the output to drop volts as the 12v drops. Do they make anything
that will do this? What i want to do is use the 12v battery to replace the 6 c cell batteries 1.5v each that goes inside of game camera. I have
the converter that drops the right volts for camera but the output stays at 9.5v all the time. The 12v battery will drop below the rechargeable state before the camera shows any drop.
Can anyone help!
Can anyone help!
@koeton, I can't think of a regulator that will do what you want. IMO, you'll need to find some other way to monitor the 12V's voltage than using your camera's low battery detector.
There are lots of ways to drop voltages. My new favorite are these regulators on ebay. They work great IMO. I used one in my cheap bot.
http://www.amazon.com/PAC-BG-12-BATTERY-GUARD-VOLT/dp/B001EAQTQO
Batteries vary greatly from their labled voltage.
You may not need to provided regulated input.
It might be cheaper to find the right battery pack than to get involved with converters.
To do so, get some realistic parameters of the operating voltage of the device. Never exceed the labled high side limit, but you may be surprised by how far you can go below.
Of course a 12v lead acid battery is never really 12volts, it is nominally 12 volts but actually higher.. maybe 13.2 volts. In automotive context when charging the voltage might go as high as 14.2 volts.
The whole project might a lot easier, less wasteful with 9.6 volt battery pack.. Lithium ion (at 3.2 volt cells) or NiMH (?) in series.
If the 9.6 volt is too high, it can be dropped with a resistor or a variety of diodes. Rectifier diodes drop about 1.0 volt, and Schottky diodes can drop at little as 0.3 volts. I do suspect that 0.1 over-voltage is not serious.
Completely eliminate the converter as it just wastes energy and cost more money. Select a cell that is easy to buy with a charger, such as the 18650 Lithium Ion or the NiMH.
I think if you test a fresh set of 1.5 volt cells, you are going to see they are significantly over 1.5 volts and 6 in series is delivering more than 9.5 volts.. the camera likely has an internal regulator and accepts variable voltage within a range. Hopefully the external input goes through that protection and regulation as well.
You can buy an 8 Volt Lead Acid Gel cell, charge it with a 500ma 9 volt wall wart and likely use that directly. The six 1.5 cells are also an optimal estimate. Do a test to see if the camera runs fine as low as 8 volts DC.
If I found 14.2V in my car when charging, I'd assume that the alternator is dying.
(14.4V is a requirement when living in a country covered in ice for so many months every winter.)
Converters...
If you're lucky, the converter hits 85% efficiency. In reality, a good DC-DC converter will get you around 80%.
A bad one (containing a 780x chip or similar) will waste any voltage over the specified output voltage.
So, at least 1/5 of the battery pack will be wasted...
But even a 3.2 Lithium battery may provide 3.9 volts when fully charged, and 3.7 lithium may go to 4.2 volts. So every battery chemistry requires either the insertion of a voltage regulator or fully knowing what the batteries voltage range is going to be in use. Testing brand new fully charged batteries will tell a lot about the highest voltage an appliance will accept.
Reading consumer electronics information is likely to just leave you confused.
For the lowest operating voltage, one needs to provide power via a good variable voltage supply and see when the device stops operating.
That should solve the problem for a device that suffers damage only from excessive voltage, but the world has grown more complex. LED actually can handle very high voltages, if the current is limited. So for those we tend to use a combination of current and voltage limiting to avoid damage. It might help to consider the this situation an excess of watts in or watts out.
And to make matters more awkward, newer batteries these days operate very differently. Not only excessive charging can cause damage; the newer batteries have both a high volt limit when charging and a low volt limit when discharging. Lithium batteries will short circuit if you discharge below a certain voltage. So you have to be sure the device shuts down before the cell reaches the low voltage boundary. And this gets more tricky if you are driving high power drains on a lithium cell.
The good news is that if you understand all that, you can eliminate regulators and get a lot more power from your batteries.
Thanks for all the replyes
What I am trying to do is make the camera work as the 6 c cells batteries does, the camera shows % as the c batteries drop from taking pictures. That is why I would like
to make the output drop as the input drop. The regulators you are talking about looks like they will only take 3 amps in, the 12v battery has 7amps. What I really want to do
is make the battery last longer then the c cells do, but need to know when the battery is getting low.
Thanks for your help
Koenton
Thanks for your reply
The input 12v 7amp rechargable battery will be 13.8 v after I charge it, but the converter drops it to 9.5v. What I want to do is make the camera work the same as the c cells battery does.
The camery shows the drop in % as the c cells battery drops. I want to use the 12v battery to make the battery last longer than c cells do, but don't have any way to monitor the 12v battery.
I thought if the output would drop as the input drops it would make the camera show the drop so i could tell when i needed to recharge battery. Or what do you think would work?
Thanks for your input
Batteries have several ratings. One is the capacity often measured in milliamp hours (mAh) or amp hours (Ah). The regulator doesn't care at all about the capacity of the input voltage battery just the current (and voltage) passing through the regulator.
If you mean your camera needs 7 amps, then there's a problem using a 3 amp regulator but I'd be very surprised to learn a camera running off of 6 C cells draws anywhere near 7 amps of current. Now it it were a radio controlled airplane, I wouldn't be as surprised.
How long does the charge of 6 C cells last? If you don't know the current draw of the camera we might be able to make an educated guess based on how long a charge lasts.
Ummm. There are some added problems with using the camera's battery guage. If it only measures the change in voltage it is not useful for new battery chemistries. Newer batteries have an extremely flat middle section of their discharge curve. Most of the time a 3.2 volt Lithium just hangs at 3.2 volt with a sudden fall as it nears empty.
So newer batteries require monitoring time in use, change in voltage, change in current, status as charging or discharging. This is quite a bit of data to accumulate and interpolate. Personally, I'd use an 8 volt lead acid cell and hope that it would reflect on the existing guage. The 8 volt lead acid will provide 9.2 volts if fully charged and there is a good possibilty that the camera will operate well at 8 volts. You would just have to adapt to what the gauge tells you to know when a shut down is extremely likely.
Where can I buy a 8v sealed lead acid battery, will try one if I can find out where to buy
Thanks for info.
something else. What I wanted to do is use the 12v battery to make it last longer than the c batterys, wanted to know what volts were left in battery when I
go to check it. I only check it about 1 time a week. Was told I could get a 8v sealed lead acid battery that might work. But only found 2 ea on ebay and they
were 3.2 ah also were very high.
Thanks for your input.
Kwinn
Where could i get the zener diode and would i put it in + or - line, between battery and converter if i try that? Also would that read the drop in the battery?
Would the zener diode drop as battery drops?
Thanks for info.
The diode would be used instead of the regulator. By placing it between the 12V battery and the camera it will reduce the voltage the camera sees by the voltage rating of the zener diode. For example, if the 12V battery put out 12.6V and you had a 3V zener between the battery and the camera the camera would see 9.6V. When the battery voltage drops to 12.0V the camera would see 9.0V.
Thanks again to everyone
Will in Al
