Problem with Stamp BOE
Hi all....
I was working with one of my 'bots controlled with a Stamp BOE and ran into a problem. Any servo connected to servo header 15 runs in the same direction, at the same speed no matter what command I send to it. I'm not sure what might be causing this... Could the Stamp module be damaged? Any way I could have damaged the board?
Any advice would be appreciated!
Amanda
Amanda
It's just a trace from "P15" to that header.
I keep an LED soldered to a resistor handy for this sort of situation. I would disconnect the servo and upload a pin 15 high / low program and test the output with the LED. If that works I would then connect a switch to the pin with some resistors to limit current and test the pin as an input. If that works I would use a DMM to test continuity and voltage at the header.
Battery good?
Working on it in the morning. Been a very lazy weekend. I'll let y'all know asap. And thanks for the input!!!!!!
Amanda
I swapped another Stamp into the BOE and everything worked as it should. Then I put the suspect critter into another BOE and the problem reared its ugly head.
So, I guess the problem with the servo is solved, but I don't understand what happened to the Stamp. Between the time it was working and the time it stopped, the only thing that changed was the date... same battery, same program.
Nothing lasts forever, eh?
Amanda
A program to toggle an LED on Pin 15 sort of works. If I set up the hardware so the Stamp supplies VSS to the LED circuit, it works. If I reverse it so the Stamp supplies VDD, it doesn't. Does this seem reasonable? Can a bad pin not go High or not go Low? Floating between both in some state?
Just trying to understand what the module is up to. :-)
Amanda
Sure Martin, on both items... a project for tomorrow. Engrossed in watching the sci-fi flick "Reptilicus" right now. Another of the things that can grab my attention. :-)
@ - Wishing I knew the workings inside this beast! Edit: Not the movie beast!
I'm glad you have your priorities in order. I love the movie Reptilicus!
Glad you are on the road to a solution ajward...
