Quickplayer Launcher Menu
skylight
I finally got hold of an sd card that works with the player and loaded it with the dmp files and games binaries, the quickplayer menu shows with the flashing arrow but no list is shown either of the sound files or the games just the menu title the flashing arrow and the scrolling greetings at the bottom?
Am I right in putting the files straight onto the SD card in the root or should they be in directories? If so what should the directories be named as?
The tunes do play btw but looking through the launcher code the get list routine should get and display the filenames?
thanks for any help
skylight
thanks for any help
skylight
Jeff
Ok very starnge just tried again and there they are!
ok thanks Jeff I'll change the thread to solved.
