Serial Bluetooth Helper
Oldbitcollector (Jeff)
I had the need to be able to easily change the Blueooth settings on those serial bluetooth modules without having to create a PC interface to connect them.
The Propeller is perfect for this job! So I created a program called Serial Bluetooth Helper which you can load on your Propeller, then interact with the Bluetooth module by VGA/Keyboard on the Propeller (It's a VGA terminal program) or from a remote terminal on the PC at the same time. I'm recommending TERA TERM for this, as Parallax Serial Terminal doesn't play nice with the copy/paste AT command requirement of the Bluetooth modules.
Details on this and the program are here:
http://propellerpowered.com/forum/index.php?topic=386.0
Jeff
Jeff
http://propellerpowered.com/shop/?page_id=1748
Jeff
