Questions about applying the PLX-DAQ code for real work outside of the examples
Buck Rogers
Hello!
I downloaded yesterday the PLX-DAQ setup. Loading the example sheet and running the macro was exactly as the help screens insisted. But running the demo got me thinking about applying the code to actual programming. For example in the help screens there is this one fragment:
I then loaded the supplied example and discovered much the same methodology is used there.
After running the example once or twice, or was it three times, I came to the (probable) conclusion that the whole thing runs in much the same way as having the stamp send its data back to the IDE whilst it is running and then display the same data via the debug window.
But in all actuality, how to definitely apply that method to the programs that I would write? That is the question.
[B][COLOR=#020FC0]SEROUT[/COLOR] sPin,Baud,[[COLOR=#ff0000]"DATA,TIME,TIMER,"[/COLOR], [COLOR=#020FC0]DEC[/COLOR] X, [COLOR=#ff0000]","[/COLOR], [COLOR=#020FC0]SDEC SIN [/COLOR]X[COLOR=#020FC0], CR[/COLOR]][/B]
[FONT=Tahoma][SIZE=2] [B][COLOR=#020FC0]SEROUT[/COLOR] sPin,Baud,[[COLOR=#ff0000]"ROW,GET"[/COLOR],[COLOR=#020FC0]CR[/COLOR]][COLOR=#008000] ' Request Row [/COLOR]
[COLOR=#020FC0] SERIN[/COLOR] sPin, Baud,200,TimeOut,[[COLOR=#020FC0]DEC[/COLOR] Row] [COLOR=#008000]' Accept returning data with timeout[/COLOR]
IF Row >= 300 THEN [COLOR=#020FC0]SEROUT[/COLOR] sPin,Baud,[[COLOR=#ff0000]"ROW,SET,2"[/COLOR],[COLOR=#020FC0]CR[/COLOR]] [COLOR=#008000]' If Row is or exceeds 300, set row back to 2
[/COLOR][/B][/SIZE][/FONT]
Hello!
Makes sense Mike. Lots of questions but my answers are outside of the forum.
