ACM08Y/RS232
protocol description and installation manual
Baud Rate::9600BPS
Sync Bit:None
Data Bit::8
Stop Bit :1
In RS232- TTL module output interface, it has 12 ASCII codes,01 in the first ,
02 in the last ,10 card numbers are in the middle.
For example:
HEX: 01(first) 30 31 30 39 33 36 36 37 32 35 02(last)
ASCII: 01(first) 0 0 1 0 9 3 6 7 2 5 02(last)
The card inner code:
HEX:84C2A6E195 A6E195(HEX) = 10936725(decimal)
RS232 Connection is as follows: Red Wire: Connecting Power Positive Side
Black Wire: Connecting Power Negative Side
Blue Wire: Connecting Feet 2 of the 9 PIN Serial Port.
And Serial Port 5 should also connect Negative Power side.
Computer Setting
Computer Start – Programs – Accessories – Communications – Hyper Terminal. ű
(First Choice: COM Port 1.)
Baud Rate: 9600.
Data Bit: 8.
Stop Bit: 1.
Parity check: No. OK.
http://www.soselectronic.com/a_info/resource/c/ACM08Y.pdf
http://www.soselectronic.com/?str=371&artnum=105640&name=ACM-ACM08Y-RS485#tabs-1
http://www.alibaba.com/product-gs/513982956/ACM08Y_1m_middle_range_RFID_Smart.html
ACM08Y/RS232
Baud Rate::9600BPS
Sync Bit:None
Data Bit::8
Stop Bit :1
For example:
Computer Setting
Baud Rate: 9600.
Data Bit: 8.
Stop Bit: 1.
