Searching for Android tablet to be used with Parallax products
I'm trying to figure out which A10 / A13 Allwinner chipset based Android tablet would be a good candidate for a test platform to interface with BS2 and Propeller projects.
One requirement is that it has to have a built-in quad-band support for 3G: WCDMA:850/900/1800/1900/2100MHz (and EVDO:800MHz).
something like this one:
http://www.aliexpress.com/store/product/Free-shipping-F8S-3G-phone-call-7-inch-Capacitive-Screen-android-2-3-512MB-4GB-HDMI/403922_543879626.html
Any comments / ideas?
John
John
We also use Bluetooth devices to talks to props with HC05. All we do is change the serial connection pin assignments from pins 30&31 to pins 24&25 where the HC05 is.
In the above cases, I've used android 2.3 Nook Simple Touch, (Ethernet not Bluetooth) and Samsung Captivate (Bluetooth and Ethernet) up to 4.1 on Nexus 10 (Bluetooth and Ethernet).
We are also working on an android app which seems to need Android 3.2 or above (for the web stuff), but this is still in development. When complete, it should allow programmable macros associated with touch screen "buttons".
All this is built one the text - command line interface to propforth, so it may or may not be what you can use. But is you go the text command route, it can be made to work on just about any android device.
I'd like to hear from our Chinese / Taiwan folks on their experience and suggestions in regard to allwinner based tablets with built-in phone support.
I am somewhat wary of hacking into Android or being dependent on the Apps store for good development tools. But I have compiled Allwinner A10 code from scratch on a 64bit Intel machine and loaded it into a Cubieboard with an A10. The A13 is somewhat more limited in resources, so be careful if you really decide to go with an A13.
As it is, I can use an Android OS on the Cubieboard and the Ubuntu Linux (which is loaded via an SDcard). This device doesn't have a touchscreen and would be prohibitively costly to add one, but it is a great platform to work with generalized A10 development.
I had to wait a bit of time for deliver, but I now see they have stock on hand and this is more capable than a Raspberry Pi as it actually has a SATA hard disk interface and a IR remote control receiver.
http://cubieboard.org/
And it appears that my dear Cubieboard is once again sold out.
So go here and read up on what devices might be appropriate. They also suggest installing Busybox, which is a very handy set of Linux utilities, but they don't exactly explain where to get a good A10 image or how to load. You might have to compile your own Busybox to accomodate space limitations from source code.
https://play.google.com/store/apps/details?id=jackpal.androidterm&hl=en
https://github.com/jackpal/Android-Terminal-Emulator/wiki/Installing-BusyBox-and-ssh-without-Rooting-your-Device
When you've mentioned a limitation of A13- was it just its limited video support?
According to some sources the A13 is supposed to be a tad faster and at the same time approx.40% less power hungry.
What about tablets with built-in 3G support - did you come across a suitable model that you see as a good platform for experimenting further...?
The above phone doesn't seem to have a USB port, you would have to hack into a wireless interface, likely Bluetooth, to get terminal to work with a Propeller or a BS2. The lack of a USB port is highly likely with all of these... so take a good look at Bluetooth to RS232 interfaces to fill the gap.
I really like the idea of using the tablet with Android Terminal Emulator, but read all the problems with having to input ESC characters. You may just have a keyboard style interface and not be able to use some buttons or controls as you hope for.
You are expecting a bit much to find built-in 3G support, a low price, and a useful USB port. The powers that be just don't put USB ports on 3G telephones, at least not on cheap ones.
I fear you have to use Bluetooth or nothing at all.
I have seriously done my best to ignore 3G phones here in Taiwan as I pay a mere $6.66 per month for my old clunker and the service fees for 3G are much higher. Also, I don't own a tablet as I don't like smudges all over my display. I am an extremely loyal notebook computer user. And I have done the utmost to ignore Android up until I got the Cubieboard in December as I love Linux.
But I must say that your inquiry is softening my rather extreme bias as I can see a way into using this user interface.
I found this explanation http://www.spemall.com/blog/?p=821
"...Allwinner A13 is the cost down version of Allwinner A10, compared to Allwinner A10, A13 is mainly targeted the low-end tablet PC market. In order to save cost, the A13 removed the HDMI and Bluetooth module, and it’s also said that the screen resolution will also change to 800*600, or 800*480..."
Does that imply that a Bluetooth dongle attached to A13 tablet's USB port won't work at all?
What the A10 has, as have most ARM chipsets, is built-in BT hardware. So you won't need a BT dongle for those. The only problem with that is that as most Android devices have this built-in ARM chipset BT hardware there may not actually be many Android kernels out there with the USB dongle BT driver available, so that's the possible issue here.
-Tor
So reading specifications then expecting to get all deployed in one device and cheaply is just not going to happen.
I am curious if you want the 3G phone service to be linked to the Android Terminal emulation and then to go into the Bluetooth. I suspect that would not work as there might be parts of the Android OS that are just out of bounds to you. Loading Linux as root might be doable, but the drivers for 3G service may be non-existent proprietary code.
If I were to buy a 3G Tablet with Android, I would expect to mostly use it as it was intended and consider the hacking with Android Terminal as an interesting additional benefit that is likely to demonstrate some proprietary boundaries. I went with the Cubieboard just to have Linux in an A10 as it is a wonderful small, extremely low power device that can sit on a network 24/7 with a SATA hard disk and be a Linux server. Why bother with running 300 or more watts, when this can do it for so much less? Ane with a much smaller footprint.
The Raspberry Pi can do a lot, but it is less than the Cubieboard. There are also the Beagleboard, the Pandaboard, and the Beaglebone.
As i said im sorry if you were looking for wireless solutions only, but as loopy said BT will work. These chips would allow alot more though, maybe you want to funnel camera data to the prop etc.. then check in to usb host solutions. I dont know all the details as i havent had any time to learn how to use the android ADK, but im betting the FTDI data sheets would be a good start, or the Arduino ADK schematics/firmware.
Thank you all - it seems quite reassuring the BT option is a way to go and should work as expected.
Time to start searching for specifics of the ADK support...
You may start out with Android and I do think that is the wisest way to go, but the choices of software may shift in favor of using Ubuntu Linux.
