RC receiver to prop hookup
Hey guys i have a spectrum dx6 receiver that i want to hookup to a prop. The pwm signal is 5 volts. Can i hook the signal wire straight to the input pins on the prop or do i need to put a 100 ohm resistor between the two.
I generally use 10K ohm resistors with 5V inputs since it's a relatively common resistor value and the Prop doesn't have any trouble reading the signal with a 10K resister in series.
Now if I send a pwm signal from my prop to an esc signal wire would I use a resistor for that also.
I have hooked the prop straight up to one for test purposes and it seems to work. Even though the esc is looking for a 5 volt signal.
Everything I worked with before the prop ran on 5V. It is taking some getting use to, a person just has to give a little more thought when building a circuit.
OR
You can connect the white (or lightest color - the signal wire) female connector with a male-male jumper to the breadboard
