I Thought I was beginning to understand counters
So my task is very simple. Each time the bucket tips I want phsa to increment by the calabration number determined for the raingage.
I have set up the counter with the neg edge detector no feedback. The following is my test code
Jim
CON
_clkmode = xtal1 + pll16x ' use crystal x 16
_xinfreq = 5_000_000
CS = 16 ''CS: Clear Screen
CE = 11 ''CE: Clear to End of line
CB = 12 ''CB: Clear lines Below
HM = 1 ''HM: HoMe cursor
PC = 2 ''PC: Position Cursor in x,y
PX = 14 ''PX: Position cursor in X
PY = 15 ''PY: Position cursor in Y
NL = 13 ''NL: New Line
LF = 10 ''LF: Line Feed
ML = 3 ''ML: Move cursor Left
MR = 4 ''MR: Move cursor Right
MU = 5 ''MU: Move cursor Up
MD = 6 ''MD: Move cursor Down
TB = 9 ''TB: TaB
BS = 8 ''BS: BackSpace
BP = 7 ''BP: BeeP speaker
rainpin = %0100_0000
OBJ
debug : "Parallax Serial Terminal"
rain : "raingage021413a"
delay : "timing"
Pub Main | tmp
debug.start(115200)
debug.str(string( " Bucket Tips "))
rain.Start(7)
repeat
tmp := rain.rainamt
debug.CHAR(PX)
debug.CHAR(14)
debug.dec(tmp)
'raingage obj
Con
fallingedge = %01110000_00000000_00000000_00000000
risingedge = %01010
calfact = 2111
VAR
long tipscount, cntrpin, testval
OBJ
delay : "timing"
Pub Start (datapin)
cntrpin := |< datapin
tipscount :=0
ctra:= fallingedge + cntrpin
frqa := 1' calfact
phsa := 0
OUTA[CNTRPIN] ~
outa [16] ~~
dira [16] ~~
delay.pause1ms(1000) ' wait one second
outa [16] ~
outa[cntrpin] ~
Pub rainamt
{ repeat
waitpne (cntrpin,cntrpin,0)
waitpeq (cntrpin,cntrpin,0)
tipscount := tipscount +1
Return(tipscount)
repeat
tipscount := phsa
'Return (testval)
Return (tipscount)
Pub resetrainamt
phsa := 0
The tipping bucket works with test code that uses waitpne/waitpeq and the Parallax usb scope shows a clean negitive going pulse. So when I run the above code, the counter seems to keep incrementing without the bucket moving. So where am I misunderstanding the counters?Jim
Remember that cntrpin is a bitmask and ctra needs a pin number.
Bean
Jim
The counter mode is in the bits 26..30 and not 27..31, it's much better readable if you write:
Andy
PS: what Andy said!
Jim
Here is a modified version of the raingage code:
Andy
I created a test obj which I started in a new cog:
Pub testpulse outa [7] ~~ dira [7] ~~ repeat outa[7]~ delay.pause1ms(1) outa [7] ~~ delay.pause1ms(1000)and the counter behaves correctlyJim
How far away is this hall effect sensor?
Probably a open drain type output?, though its falling edge output should be pretty fast.
Counter need faster fall and rise times than waitpeq (I would assume)
Maybe you you need to insert a Schmitt buffer closer to the Prop.
Thanks for all the help guys!
Jim
I spend hours on a PropBasic program to read from an SD card, only to discover that pin P0 was bad on my demo board (I must have shorted it at some time).
Bean
Self test code is always a very good idea, as it proves the logic, without the extra variables.
Another self-test is to generate the test edges on a separate pin, and couple that to the Test pin, via a RC. That gets closer to a real edge, and you can test the tolerance & failure modes, to edge slew
Edit: To get some ballpark numbers, take a sample rate of 12.5ns and choose a nominal signal noise level of 10mV (prop pins have no hysteresis), then rise/fall times need to be faster than ~ 3.7us.
(the faster that is, the move mV between samples, and the better the noise immunity)
Most logic will meed that, but some Opto-devices could struggle.
