I Thought I was beginning to understand counters — Parallax Forums
RS_JimRS_Jim Posts: 1,775
edited 2013-02-14 11:35 in Propeller 1
So my task is very simple. Each time the bucket tips I want phsa to increment by the calabration number determined for the raingage.
I have set up the counter with the neg edge detector no feedback. The following is my test code
CON
  _clkmode      = xtal1 + pll16x                        ' use crystal x 16
  _xinfreq      = 5_000_000
  CS = 16  ''CS: Clear Screen
  CE = 11  ''CE: Clear to End of line
  CB = 12  ''CB: Clear lines Below
  HM =  1  ''HM: HoMe cursor
  PC =  2  ''PC: Position Cursor in x,y
  PX = 14  ''PX: Position cursor in X
  PY = 15  ''PY: Position cursor in Y
  NL = 13  ''NL: New Line
  LF = 10  ''LF: Line Feed
  ML =  3  ''ML: Move cursor Left
  MR =  4  ''MR: Move cursor Right
  MU =  5  ''MU: Move cursor Up
  MD =  6  ''MD: Move cursor Down
  TB =  9  ''TB: TaB
  BS =  8  ''BS: BackSpace
  BP =  7  ''BP: BeeP speaker
  rainpin = %0100_0000
OBJ
  debug : "Parallax Serial Terminal"
  rain  : "raingage021413a"
  delay : "timing"
Pub Main | tmp
  debug.start(115200)
  debug.str(string( " Bucket Tips "))
  rain.Start(7)
   repeat
    tmp := rain.rainamt
    debug.CHAR(PX)
    debug.CHAR(14)
    debug.dec(tmp)
'raingage obj
Con
  fallingedge = %01110000_00000000_00000000_00000000
  risingedge = %01010
  calfact = 2111
VAR
   long  tipscount, cntrpin, testval
OBJ
  delay : "timing"
Pub Start (datapin)
   cntrpin := |< datapin
   tipscount :=0
   ctra:= fallingedge  + cntrpin
   frqa := 1' calfact
   phsa  := 0
   OUTA[CNTRPIN] ~
   outa [16] ~~
   dira [16] ~~
   delay.pause1ms(1000)                              ' wait one second
   outa [16] ~
   outa[cntrpin] ~
Pub rainamt
{   repeat
        waitpne (cntrpin,cntrpin,0)
        waitpeq (cntrpin,cntrpin,0)
        tipscount := tipscount +1
        Return(tipscount)
    repeat
      tipscount := phsa
      'Return (testval)
      Return (tipscount)
Pub resetrainamt
    phsa := 0
The tipping bucket works with test code that uses waitpne/waitpeq and the Parallax usb scope shows a clean negitive going pulse. So when I run the above code, the counter seems to keep incrementing without the bucket moving. So where am I misunderstanding the counters?
Jim
    edited 2013-02-14 08:17
    One obvious thing ... do "ctra := fallingedge + datapin" instead of "ctra := fallingedge + cntrpin"
    Remember that cntrpin is a bitmask and ctra needs a pin number.
  • BeanBean Posts: 8,129
    edited 2013-02-14 08:19
    The hardware counter is able to detect much faster edges than the waitpne/waitpeq loop (spin is not all that fast). So there is probably very fast bounce in the signal that is getting counted.
    Bean
  • RS_JimRS_Jim Posts: 1,775
    edited 2013-02-14 08:25
    Thanks Mike, so I replaced cntrpin with datapin and it still increments!
    Jim
    edited 2013-02-14 08:29
    Thanks bean, I don't see any bounce on the scope. However the counter keeps going with the bucket disconnected from the input port.
  • AribaAriba Posts: 2,695
    edited 2013-02-14 08:41
    Your have the counter mode bits at the wrong position if you write:
    The counter mode is in the bits 26..30 and not 27..31, it's much better readable if you write:
    fallingedge = %01110 << 26
    Andy
    edited 2013-02-14 08:44
    Jim, you have the high byte of fallingedge as 01110000 when it should be 00111000. The way you have it is "LOGIC B" mode, not NEGEDGE.
    PS: what Andy said!
    edited 2013-02-14 08:45
    I have tried shorting the input pin to both ground and + 3.3
    edited 2013-02-14 08:51
    Ok, so I tried Andy and Tracy suggestion and bucket tips stops incrementing at all.
    edited 2013-02-14 08:58
    The bucket sensor is a hall effect sensor that generates a very nice clean negative going pulse.
    Jim
    edited 2013-02-14 09:31
    You use at several positions in the code a pin mask instead of a pin number (OUTA[], DIRA[] CTRA (as Mike said)
    Here is a modified version of the raingage code:
    'raingage obj
    Con
      risingedge = %01010
      calfact = 2111
    VAR
    Pub Start (datapin)
       cntrpin := datapin
       ctra:= fallingedge<<26 + cntrpin
       frqa := 1' calfact
       phsa  := 0
       outa [16] ~~
       dira [16] ~~
       waitcnt(clkfreq + cnt)
       outa [16] ~
    Pub rainamt
       return phsa
    Pub resetrainamt
       phsa := 0
    Andy
    edited 2013-02-14 09:51
    So now I am more confused than ever,
    I created a test obj which I started in a new cog:
    Pub testpulse
        outa [7] ~~
        dira [7] ~~
        repeat
          outa[7]~
          delay.pause1ms(1)
          outa [7] ~~
    and the counter behaves correctly
    edited 2013-02-14 10:04
    Thanks for the input Andy. I tried your changes but still no joy from the bucket. When I start the testpulse cog, the counter increments about 1 per second as I was expecting. So it appears to be a hardware interface issue. But why would it work using the code with waitpeq/waitpne and not with the counter?
    Jim
  • tonyp12tonyp12 Posts: 1,951
    edited 2013-02-14 10:26
    How far away is this hall effect sensor?
    Probably a open drain type output?, though its falling edge output should be pretty fast.
    Counter need faster fall and rise times than waitpeq (I would assume)
    Maybe you you need to insert a Schmitt buffer closer to the Prop.
    edited 2013-02-14 11:27
    Ok, it always helps to connect the hall sensor to the pin that the counter is looking at! I had disconnected sensor from seven and put it back on six. Now with the mods all is working well. Now to see if I can get rain gage to run in its own cog.
    Thanks for all the help guys!
    Jim
    edited 2013-02-14 11:34
    LOL, I think we've all been there Jim.
    I spend hours on a PropBasic program to read from an SD card, only to discover that pin P0 was bad on my demo board (I must have shorted it at some time).
    Bean
  • jmgjmg Posts: 15,200
    RS_Jim wrote: »
    Self test code is always a very good idea, as it proves the logic, without the extra variables.
    Another self-test is to generate the test edges on a separate pin, and couple that to the Test pin, via a RC. That gets closer to a real edge, and you can test the tolerance & failure modes, to edge slew
    Edit: To get some ballpark numbers, take a sample rate of 12.5ns and choose a nominal signal noise level of 10mV (prop pins have no hysteresis), then rise/fall times need to be faster than ~ 3.7us.
    (the faster that is, the move mV between samples, and the better the noise immunity)
    Most logic will meed that, but some Opto-devices could struggle.
