How do I use the PTP as a VGA replacement?
A friend of mine obtained a Propeller Touchscreen Platform with 4.3" Touchscreen. He asked me to help him get a series of VGA menu screens transferred over to it. However, when I add code of any size at all I get a compiler error saying out of memory.
The graphics demo has the following statements:
This seems to be the culprit. All he really needs are screens to match the vga (~30 cols x 13 rows) along with a vga like object (vga.str, vga.out, etc.). Has anyone worked on this sort of thing for the LCD display?
sm
screensize = 20 * 15 _stack = ($3000 + $3000 + 200 + 2 * screensize) >> 2
sm
http://www.rayslogic.com/Propeller/Products/PTP/PTP.htm
But, this is a 3.5" screen. If you really have a 4.3" screen maybe you have a PSB equivalent:
http://www.rayslogic.com/Propeller/Products/PSB/PSB.htm
If I use the graphics object I see I can use
gr.textmode
gr.text
to display alphanumeric.
sm
You have plenty of space on the SD-card! For menus and stuff it is fast enough! So, put all the strings you need to display on the SD-card and load them just before display. I enhanced the FSRW with some functions which make copying things from and to SD-card very easy and there is no FAT32 overhead.
http://forums.parallax.com/showthread.php/117573-Virtual-Memory
There are tools on my website to create 1-bit and 2-bit bitmaps that can be used here...
