RFID read issue with #28440 read/write RFID board.
I am using the test code on arduino.cc modified for the arduino mega. It was working at first but now all I get is -1 for each byte response for all tags.
Here is the test code.
Here is the output of the serial window.
Not sure why this started. I have of course repowered everything. Uploaded the code several times. Still nothing but -1 its like the board is not working anymore.
//Code to read data from Parallax RFID reader/writer 28440 via Arduino//Program reads data from the old EM4100-based tags and prints their value in the serial monitor.
//Writen by vgrhcp, uberdude, sebflippers and sixeyes
#define RFID_LEGACY 0x0F
int val = 0;
char code[11]; //Note this is 11 for the extra null char?
int bytesread = 0;
void setup()
Serial.begin(9600);
Serial1.begin(9600);
// pinMode(2, OUTPUT);
// pinMode(4, OUTPUT);
Serial.println("RFID Read/Write Test");
void loop()
Serial1.print("!RW");
Serial1.write(byte(RFID_LEGACY));
if(Serial1.available() > 0) { // if data available from reader
if((val = Serial1.read()) == 10) { // check for header
bytesread = 0;
while(bytesread<10) { // read 10 digit code
if( Serial1.available() > 0) {
val = Serial.read();
Serial.println(val);
if((val == 10)||(val == 13)) { // if header or stop bytes before the 10 digit reading
break; // stop reading
code[bytesread] = val; // add the digit
bytesread++; // ready to read next digit
if(bytesread == 10) { // if 10 digit read is complete
Serial.print("TAG code is: "); // possibly a good TAG
Serial.println(code); // print the TAG code
delay(3000);
bytesread = 0;
delay(500); // wait for a 1/2 second
RFID Read/Write Test-1 -1 -1 -1 -1 -1 -1 -1 -1 -1 TAG code is: ÿÿÿÿÿÿÿÿÿÿ -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 TAG code is: ÿÿÿÿÿÿÿÿÿÿ -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 TAG code is: ÿÿÿÿÿÿÿÿÿÿ -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 TAG code is: ÿÿÿÿÿÿÿÿÿÿ -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 TAG code is: ÿÿÿÿÿÿÿÿÿÿ -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 TAG code is: ÿÿÿÿÿÿÿÿÿÿ -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 TAG code is: ÿÿÿÿÿÿÿÿÿÿ
