Help Choosing probes for my oscilloscope
Hello Everyone
I have just been given my friends old Tektronix Oscilloscope, but did not get any probes with it.
I can see that I need probes with a BNC connection but which probes are best for my oscilloscope.
Can anyone help me select some probes from this list
Or would I better off making some? are they hard to make?
Thank you in advance
The 10X allows you test higher voltages, but these days voltage are so low, you might just get by with a 1X
You didn't mention the bandwidth of the scope -- 20Mhz or 100Mhz. A higher frequency requires better, more expense probes.
And then there is the style.
Do you want to poke a probe into circuits or do you want to have a hook connect and stay in place while you monitor?
Lots of choices, but much depends on what you really need to use the scope for.
I'd start out with a cheaper !x and use that for most of my work. Later I'd buy more expensive probes as I needed to. A lot can be learned without having to get into extremely precise measurement. Get to know the scope first. You might try Ebay for some probes.
http://www.ebay.com/sch/Probes-/50971/i.html
Though my scope came with a single probe, I got a pair from eBay for, like, 10 bucks. ('Sides my scope was dual channel and I wanted to play with it!) :-)
Elenco 250MHz Scope Probe, Switchable, OUR BEST! # P-3E
http://cs-sales.net/p3d.html
What is the model # of your scope? That makes all the difference in probe choices.
No, I'd definitely avoid a 1X - the capacitive loading of a 1X probe is too high for lots of interesting circuits, a x10 (shouldn't that be
/10 ??) probe means only a handful of pF loading on the probe meaning much less disturbance to the circuit being measured. Also
you will not get the full bandwidth except on low impedance sources. Also leaving the probe on x10 setting means the 'scope is safe
from accidental high voltages.
Cheap and cheerful ones on eBay are so cheap its worth getting even if they then just become emergency spares, for instance
http://www.ebay.co.uk/itm/2-X-100MHz-Scope-Probes-for-Oscilloscope-UK-X1-X10-Pair-Two-/181003163091?pt=UK_Sound_Vision_Other&hash=item2a24a115d3
Oh, yeah, watch out from where it is sources from, took a couple weeks for their world tour before I got them.....
FF
If you want fast shipping from US Parallax also sells scope probes at $8.99 per set of two (x1, x10 up to 20 MHz):
http://www.parallax.com/StoreSearchResults/tabid/768/txtSearch/PROBES/List/0/SortField/4/ProductID/754/Default.aspx
I think their current probes may be actually 100 MHz ones, so if your scope goes beyond 20 MHz you may check with them for current max frequency.
