Tiny RTC clock module w/Supercap backup — Parallax Forums
RaymanRayman Posts: 16,271
edited 2013-02-10 15:31 in Propeller 1
Just finished testing this new I2C RTC clock module and it appears to work perfectly.
This module features the smallest SMT chip, crystal, and supercapacitor I could find...
Here it is soldered to the Propeller Platform Express's second eeprom socket:
It actually only needs pins 5,6,7 and 8 to function, so it could be used as a 4-pin SIP module instead of 8-pin DIP...
These Mill-Max stackable headers seem to be pefect for this as I can still attach something else on top:
These ones are a little too long for my taste though, so I'm ordering some shorter ones from Digikey to try out.
The Digikey part number is ED90249-ND.
Since this is perhaps the smallest supercapacitor out there, I was a bit worried about how long it could backup the clock. But, I left it overnight and it still had the time in the morning. So, it's good for at least 10 hours. I'd have to break out some datasheets and a calculator to figure out how long it can go...
  • cavelambcavelamb Posts: 724
    edited 2013-02-10 08:50
    Nicely done, Ray!
    edited 2013-02-10 10:28
    I bought an RTC clock a while back and I was wondering about backup power. Are there any guidelines on capacitor choice?
  • Don MDon M Posts: 1,654
    edited 2013-02-10 10:49
    Ray- what RTC chip are you using?
  • RaymanRayman Posts: 16,271
    edited 2013-02-10 12:08
    I'm using DS1339 here.
    It has a very flexible trickle charger with options to support many types of backup capacitor...
  • TubularTubular Posts: 4,771
    edited 2013-02-10 14:53
    Really nice work, Ray. The 4 pin (SIL) function is great too
    If you do a revision perhaps some pads for external connection (so a larger supercap can be optionally connected)
    I thought about pads for larger supercap or battery, but was more interested in making it smaller and I thought that would make it bigger...
    One can remove this supercap pretty easily though and expose the pads that could be used for something else...
