Bot steering wheel
Im getting to the stage of my electric go-kart robot thing (it has like 6 names) where the steering wheel must take shape. I'm planning to use a Formula 1 style design (http://luxedb.com/wp-content/uploads/2011/07/Ferrari-F1-Steering-Wheel-Replica-for-Passionate-Gamers.png) but instead of all the buttons i have to fit a TI AM335X starter kit (http://www.ti.com/tool/tmdssk3358) which is 5 1/4 inches across and 2 1/2 inches up. the distance between the screw standoffs are 4 5/16 inches across (width) and 2 inches apart top to bottom. Along with this is a 4 AA battery pack (the one that comes with boe-bot kits) and a JEGs quick release (http://www.jegs.com/i/JEGS+Performance+Products/555/60720/10002/-1). To make this steering wheel as timely and easily as possible, suggestions on design and or build materials????????
I was only offering alternative suggestions. You may be able to use the steering wheel you suggested in your first post if it is rugged enough. If you intend to drive the robot at high speed for any amount of time a plastic steering wheel may not be sturdy enough. A steering wheel for a go-cart or car certainly will be rugged enough and there are several models that have enough space in the center to mount the module you have in mind.
Take a look at http://www.bmikarts.com/Steering-Wheels_c_275.html for some examples.
