Connecting the mobostamp to an Arduino microcontroller
Good day! My classmates and I are currently working on a project wherein we have to detect color from the TCS230-db connected to the mobostamp and interface it to an Arduino microcontroller and display data on an LCD. Right now, we are already done in the arduino part and mobostamp codes, we can already detect RGB colors from the tcs230 sensor. Our problem now is on how we are going to connect the mobostamp and transfer its data to the arduino microcontroller( Our microcontroller contains equations and conditions regarding the RGB colors so we cannot disregard it and just connect the mobostamp to an LCD) We tried USB to Serial connection, USB to UART converter and USB to TTL converter since the arduino microcontroller seems to accept only TTL from another microcontroller. Is it possible to interface this two microcontrollers? help please
thank you very much!
http://www.parallax.com/Store/Accessories/CablesConverters/tabid/166/txtSearch/28317/List/0/SortField/4/ProductID/433/Default.aspx
Hello!
Excellent suggestion. But I'd also suggest this one:
http://www.parallax.com/Store/Microcontrollers/BASICStampDevelopmentBoards/tabid/137/txtSearch/28317/List/0/SortField/4/ProductID/469/Default.aspx
That's the Prototype Daughterboard. It provides a method to attach your gadgetry to the Mobo. Naturally those three would be attached to the B connector.
Thanks. Yes, that's an excellent suggestion! And potentially less expensive, too.
