code problem — Parallax Forums
code problem
mikeamikea Posts: 283
edited 2013-02-07 17:39 in Propeller 1
The following will ramp up a led until i added the "repeat while ina[1]==1. I,ve spent a lot of time and i'm still stumped. In the future i want 2 buttons to ramp up/down a dc motor, but i'm stuck here. thanks for any help.-mike
CON
_clkmode = xtal1 + pll16x ' System clock → 80 MHz
_xinfreq = 5_000_000
PUB TestPwm | tC, tHa, t
ctra[30..26] := %00100 ' Configure Counter A to NCO
ctra[5..0] := 4
frqa := 1
dira[4]~~   'pin for led
dira[1]~
tHa:=1
tC := 10000 ' Set up cycle and high times
t := cnt ' Mark counter time
repeat
   repeat while ina[1]==1   'pushbutton held down
      phsa := -tHa ' Set up the pulse
      ++tHa
      t += tC ' Calculate next cycle repeat
      waitcnt(t) ' Wait for next cycle
  • AribaAriba Posts: 2,695
    Here is an untested code that ramps up and down with two buttons. It also makes sure hat the PWM value is always inside 0..10000.
    CON
     UP    = 1  'button pins
     DOWN  = 2
     SPEED = 1  '1=slow .. ~100=fast
     ctra[5..0] := 4
     frqa := 1
     dira[4]~~   'pin for led = output
     tHa:=1
     repeat
        if ina[UP]==1 and tHa < 10000
           tHa += SPEED
        if ina[DOWN]==1 and tHa > 0
           tHa -= SPEED
    Andy
