Hard of thinking - Data sent to parallax serial terminal
Hugh
Hi,
I have the following code generating data from an MCP3208:
When started, the data shown on the Serial Terminal is about what I expected, but as a concatenated continuous stream of numbers.
I added Line1 to try and add a delimiter: all the data went to 0.
I added Line2 to try and add a line feed: all the data went to 0 (albeit in a line scrolling across the display window).
The (default) preferences in serial terminal appear to be correct, i.e, ASCII 10 = line-feed. I have also tried sending PUTC(13).
If anyone has ideas as to where I might be going wrong I would be very grateful for suggestions or comments.
Hugh
CON
_clkmode = xtal1 + pll16x 'Set up frequency and clock data
_xinfreq = 5_000_000
pinCLK = 0
pinDIO = 1
pinCS = 2
VAR
byte Stack2[500]
OBJ
ADC : "MCP3208"
DEBUG : "SimpleDebug"
PUB Main | i,r
DEBUG.Start(9600)
waitcnt(15000000+ cnt)
r := cognew(ADC.start(pinDIO, pinCLK, pinCS, %11111111), @Stack2)
debug.dec(r)
repeat
waitcnt(1500000+ cnt)
DEBUG.dec(ADC.in(0))
'debug.str(string("-")) '<----- Line1
'debug.putc(10) '<------Line2
Hugh
So, your cognew won't do what you expect. And usually you don't have to call cognew for objects at all, because that is what a start function would do for you if the object really needs a COG!
If you have a look at the source of MCP3208 you'll see, that it really is doing a cognew inside of the start function.
Sometimes the more you stare at something, the less obvious problems become.
D'Oh!
