Has Anyone ever made a DIY SlipRing
I need to get some wiring to travel in to a cylinder that rotates 360degrees, and I was looking at premade solutions, they all seem kind of pricey, maybe not, im not sure what actually goes in to one of these.
Imagine you had a square platform with batteries and circuit boards on it, then you had something the shape of a pringles can mounted to the square platform that rotated 360 degrees using a stepper motor. On this cylinder you had ping sensors or leds or something like that mounted to the walls, now you need to run the connections for those components to the bottom of the cylinder, and out to the stationary square platform holding all the power and brains.
Anyone have a homemade way to get this done? Or something cheaper than 20 bucks for only a few wires. Im having a hard time even imagining how this would work without breaking the wires and connecting them to 2 pcb's with a ring for each wire, that could spin freely. Im pretty sure that made no sense but no matter im hoping there is a much simpler way to get this done.
http://en.wikipedia.org/wiki/Rotary_transformer
The above link is more of a reference, but they can be scaled to provide larger amounts of power. Even with data communication.
@Franklin, adafruit slip rings were the original products I was looking at but there fairly exspensive, a headphone jack is a good idea if only a couple wires were needed! Alas Ill probably be running 20 wires or more between the rotating cylinder and the motor platform
@Beaua, id never seen these looks like a much better idea than a slip ring, the article says these are commonly used in VCR's I wonder if I could just pull one out of a VCR and reuse it, do you have any suggestions for a premade rotary transformer? I would need to pass a lot of 5/3,3v data lines and a power line up to 18v
C.W.
So far the RJ11 Swivel telephone adapter suggested by Erco, is the best one I've seen so far.
Building a swivel connector with slip rings gets complicated in that the alignment with bearings and brushes of some type is
difficult to achieve.
I've had some success at winding a ribbon cable inside of a container and connecting the outlet end to the swivel.
This causes trouble, because you need to limit the rotation to however many wraps are wound inside of the container.
Sometimes the ribbon cable kinks and ruins the rotation.
The rotation also needs some type of mechanical stop, if slip rings are not used.
I'm thinking that the moral of the story is:
Try something like the RJ11 Swivel to see if the electrical noise made by the slip rings works in your application.
That's just my 2Cents worth.
Duane J
+1
Now you can make a spinning Linda Blair head.
EDIT:
Oops that for rj11 phone connectors, still a good solution, and im sure they make the same type of deal for rj45/cat5
Adafruit is a good option to find the wires. You can also see few Slipring suppliers who can give you the required stuff.
Why does it seem like spam?
1. It's "felixmtt"'s first post
2. The lack of connection between the two sentences is a poor transition to his topic (and don't make sense together).
3. The link is not useful to this thread.
http://www.ebay.com/itm/250Rpm-12-5mm-6-Wires-6-Conductors-Capsule-Slip-Ring-220V-AC-F-Monitor-Robotic-/290696966126?pt=LH_DefaultDomain_2&hash=item43aee3afee
I bought one a while back for about $8, but I don't see them that cheap right now.
Roombas Revenge
-Tommy
