Pump motor to circulate Ferric Chloride etchant?
xanatos
Anybody know of a good small volume little pump that has NO metal part contact in the liquid paths, that would be suitable for pumping Ferric Chloride etchant - a recirculator to offload the tedious task of rocking my etch tank for 15 minutes per board...
Thanks!
Dave
Thanks!
Dave
http://en.wikipedia.org/wiki/Peristaltic_pump
http://www.ebay.com/itm/Aquarium-Peristaltic-dosing-pump-Head-Marine-Magic-/281056002421?pt=LH_DefaultDomain_0&hash=item41703e4175
You might find an all-plastic unit.
I have had best results with an upright bubbler to agitate the Ferric Chloride, rather than try to pump it. This way a simple air pump attached to an expendable/replaceable piece of vinyl tuning.
Use a hinge for a pivot, a cam mounted on a slow-turning motor beneath raises and lowers the tank (sort of like a wave machine.)
Lawson
You can use glass pyrex baking dishes on it of suitable size. Heat lamp hung above it.
Variable 12 volt supply running at ~ 4 V.
Be careful of the fumes, it rusts (or corrodes) anything near it severely, bolts, nuts, cabinets, the dog.
Some kind of venting is needed, dryer vent tubing (not aluminum) with plastic fan etc;
A few nylon screws keeps the board out of the 'mud' (you'll see).
Air sparging does work.
jack
I considered air sparging but in order to etch some of the boards it seems like I'd need a LOT more etchant to have a board vertical, unless I found a very tall and thin, but wide-enough, clear plastic tank... :-) Right now I just cover the board in a tray only about an inch wider than the board on all sides, and to a depth of about 3/8" - if that - so I don't use much etchant...
Which I guess brings up another question I should have asked 30 years ago - how much copper do you REALLY get out of a given quantity of etchant? If I etch a 4" x 6" board as described above, cold, rocked, it takes about 15 minutes for the first board. If I reuse the same etchant for a second board, it can take almost half an hour, so I rarely reuse etchant, preferring instead to use fresh etch for each board. Is there some trick to keeping the etchant functional for longer?
Lastly - if I do choose to heat the etchant, what do you folks find to be a good temp?
Thanks for the thoughts...
Dave
I spilled a tub full of the stuff on a beige suit I once owned. While wearing it I might add. Anyway, by the time I got home, I rinsed the hell out of it with a hose, then threw it in the wash. The material had already decomposed significantly - you could feel the difference. So I put it in the give-away pile with a frown...
Two weeks later I went to bag up the give away collection. The material had almost completely disintegrated everywhere the etchant had spilled.
Fortunately the leg fared better! :-) 20 years and not even a stain! :-)
Dave
Here's a fairly decent resource for chemical and material compatibility:
http://www.coleparmer.com/Chemical-Resistance
the pump itself is hard on the tubing.
When the tubing fails, the pump needs to be in a tub or something to contain the mess.
Years ago, I used paristaltic pumps to move adhesive.
I've spent many hours cleaning up adhesive messes.
My peristaltic pumps were moving adhesive from a 300 gallon tank. Failures of tubing were very intense.
As I said, I put the etching container in a larger container with some very hot (just boiled) water in it. Etching just takes a couple of minutes with continuous agitation
I find that that the etchant lasts indefinitely, if I add a little hydrochloric acid when sludge forms.
http://www.allelectronics.com/make-a-store/item/VB-2/PERSONAL-MASSAGER-USED/1.html
http://www.haywardcontrolsonline.com/pdf/d_series_product_brochure.pdf
BTW, this is a good argument against an aeration pump, which is what I used, as it tends the aerosolize the etchant.
D
I'm sure that's a great tonic for the respiratory system... yikes.
Hey, and it's high in iron, too! Beats Geritol any day.
Or would the iron ions be too magnetic? Could the copper be recovered at the same time? Could electrolysis be used to speed up
etching?
D
