Robot Window cleaner
RobotWorkshop
This is a new gadget I just read about:
http://news.yahoo.com/blogs/upgrade-your-life/robot-clean-windows-well-170945635.html
What's next?
What's next?
I live in a wooded area with lots of maple and pine trees. I have to clean my gutters at least twice a year and should really do it more often. Typically this involves getting out the tall ladder and climbing up on the roof with my leaf blower. I have about 300' of gutter and it usually takes at least an hour of blowing the gutters clear. Luckily, my roof is of the low pitch type so walking around up there is fairly easy. At 69 years and climbing, though, it is getting to be a chore. The pine straw is very difficult to blow out since it knits itself into immovable blobs.
With the Looj, I still have to get the ladder out, but I don't climb on the roof (well, not until I'm finished - I'm a perfectionist so I have to blow the gutters absolutely clean - I know...). I just set the Looj in the gutter and hit switch on the remote. I do need to monitor it because it will get stuck in the dense pine straw. Sometimes I have to move the ladder down and physically adjust it, but it does all of the work and gets the gutters plenty clean. I really wouldn't have to get up on the roof if I wasn't so anal...
If you haven't tried this, its a cheap fairly elegant solution. At $2 a yard it might be cheaper and more effective than a bot.
http://www.menards.com/main/building-materials/roofing-soffits-gutters/gutter-accessories/quik-snap-gutter-screen/p-1443498-c-5812.htm
I put these up about 6 years ago after battling the zillion maple tree whipgigs in spring and leaves in fall. So far, only maintenance was due to a bird, which pried up one corner and built a nest. Only other problem was that four of my neighbors wanted me to put them up and their gutters too.
Of course, I'd rather have a bot. If it could only make its own way to the gutter and back down....
A long extension pole with an electromagnet would get it up and down.
I'm happy with my looj and leaf blower. Until I get too old to get up and down the ladder - then I'll hire a kid. Hmmm, I should hire a kid now - tell him he gets to use a ROBOT!
Now you're talking proper use of technology! Bait to get a kid to do the work! I will use this.
@kwinn - I don't know if I could even lift a 16 foot pole like that up to the gutter. 3 pounds robot and whatever for the electromagnet at the end of a long poll sounds like something is about to drop onto my head. But this is the part of the problem that needs a novel solution, how to get the bot to the gutter. Now, if the bot could CLIMB the pole.... and into the gutter.... and back down...Hmmm
Jim
http://www.youtube.com/watch?v=2FIMYZ6ubgY
A hollow pole with a motorized mechanism (similar to raising a flag) to hoist the electromagnet and robot to the gutter. The weight would be at the bottom so it would not be that hard to tilt the pole up and lean it against the gutter. When it comes to robots when there is a will there is a way to get it where you want it.
How about hoisting it up by hand using a pulley permanently attatched to the house, see drawing.
A couple of possible problems is it might be to far away to operate the Looj with the remote control from the ground and how to know where the Looj is. For that I would suggest a camera/monitor setup with the camera attatched to the top of the pole.
