Wanted: Propeller Tachometer Code — Parallax Forums
Paul Sr.Paul Sr. Posts: 435
edited 2013-02-04 22:09 in Propeller 1
I have a mini-mill and mini-lathe and I want to build Tachometer's for both. I have just embarked on a project to convert the Mill to CNC.
I have several Prop's around (and boards, and..) so I figured why not build rather than buy!! I would rather not spend the time starting from scratch - CNC is consuming LOTS of brainpower these days!!
Has anyone seen or have one built on the Propeller? If so, would you mind sharing code?
Paul
  • Prophead100Prophead100 Posts: 192
    edited 2013-02-01 18:07
    The motorminder object on the OBEX can help you do a set of tachometers. It used a modification to create a pair of ship drive shaft tachs with reverse as well using hall sensors.
  • Paul Sr.Paul Sr. Posts: 435
    edited 2013-02-02 07:39
    I will take a look - thanks a lot!
  • laser-vectorlaser-vector Posts: 118
    edited 2013-02-02 23:11
    I just wrote a dual tach myself in spin, still testing but seems to be OK. The output is the number of clock cycles elapsed since the last rising edge. Easily converted to rpm and averaged with external software, or one could even fire up another cog to run the conversion internally. I'll dig it up tomorrow and post it if you're still interested.
    Lv
  • HarpritHarprit Posts: 539
    edited 2013-02-03 08:15
    This is from my book on PASM for beginners
    It is in PASM but heavily documented so you should be able to use it even if you don't know much PASM.
    Copy it and run it. It is complete.
    The attached code has three methods
    The first displays what id going on on the PST
    The second generates a signal you can seed (programmable) for a frequency to use as a source
    if you don't have a signal to look at. Otherwise you can use your signal
    The third counts how may waves go by in three (programmable) 1/5 (programmable) second time frames and averages them
    You can construct a tachometer from that.
    This is from my book on learning PASM for beginners
    I invite comments on the code so I can make improvements.
    The book is about done.
    PASM_Tachometer.SPIN
    Function of program
    Tachometer reads the speed of an encoded motor every 5th of a second
    3 readings are taken and averaged.
    A method is provided to allow a signal to be generated on pin 8 if you do
    not have any other signal to measure.  Route this signal to pin 0 through
    a 220 ohm resistor to use it.  Otherwise it leave disconnected.
    Program         PASM_Tachometer.SPIN
    Book            PASM for beginners, Propeller 102
    Section         3 Inputs
    Programmer      Harprit Sandhu
    Date            Jan 10 2013
    Revisions:      Report errors to harprit.sandhu@gmail.com
    CON
      _clkmode = xtal1 + pll16x
      _xinfreq = 5_000_000
       vars=16
    OBJ
      fds : "FullDuplexSerial"         'for communications with PST
    VAR
      long stack2[25]                   'space for pulser cog
      long clk_Div,value[vars],delay
      byte sub_scr
    PUB Main|x                        'x is a local variable here
    fds.start(31,30,0,115200)         'start console at 115200 for debug output
    Cognew(@Read_Sig, @value)
    Cognew(Signal,    @stack2)         'set lines to outputs
    fds.tx(16)                    'home to 0,0
      repeat
        fds.tx(1)
        fds.str(string("HUB memory display"))     'print to display
        fds.tx($d)                  'new lines
        fds.tx($d)                  '
        repeat sub_scr from 0 to vars-1 '
          if sub_scr<10             'adds space for single digits
            fds.str(string(" "))    '
          fds.dec(sub_scr)          'subscript printed
          fds.str(string("   "))    'space over
          fds.dec(||value[sub_scr]) 'print value
          fds.str(string("     "))  'print spaces to erase old data overflow
        waitcnt(clkfreq/60+cnt) 'flicker free wait
        x:=x+1          'increment counter. This routine clears up screen
        if x>10         'decision point     by erasing extraneous lines of bottom
          fds.tx(16)    'clear screen       of PST display every 10 loops
          x:=0          'reset counter
    'If you do not have a signal to measure, you can use this
    'routine as a source of a signal. Vary the delay as needed.
    'You cannot use too small large a nummber. Do you know why?
    'Comment it out if you don't need it.
    PRI Signal                      'Signal generator
    dira[8]~~                       'pin 8 is output
    delay:=80_000                   'count for 1 microsec
     repeat
       !outa[8]                     'toggle signal
       waitcnt(clkfreq/delay+cnt)   'wait count
    DAT               Org       0           '
    Read_Sig  mov     nmbr,     #0          'initialize nmbr
              mov     mem0,     par         'read par into mem0
              mov     mem1,     mem0        'make mem1=to mem0
              add     mem1,     #4          'next mem location
              call    #wait_Hi              'wait for signal to become high
    do_again  call    #wait_Lo              'wait for signal to become low
              mov     temp,     cnt         'read counter to temp
              wrlong  temp,     mem0        'store in first location
              add     nmbr,     #1          'increment number
              add     mem0,     #4          'increment mem
              mov     varbl,    nmbr        'make copy of nmbr
              sub     varbl,    #5    wz    'subtract. Has it reached 5
    if_nz jmp         #do_again             'if not do again
    'at this point all five counter valued have been stored
              mov     nmbr,     #0          'reset counter
              mov     mem0,     par         'reset mem0
              mov     mem1,     mem0        '
              add     mem1,     #4          'reset mem1
              mov     stor,     mem0        '
              add     stor,     #24         'Stor is location 6
    'pointers are ready to read the four differences in counts
    do_again2 rdlong  temp,     mem0        'read temp from a location
              rdlong  temp1,    mem1        'write it to next location
              sub     temp1,    temp        'subtract the two
              wrlong  temp1,    stor        'store the value
              add     mem0,      #4         'increment to next location
              add     mem1,      #4         'increment to next location
              add     stor,      #4         'increment to next location
              add     nmbr,      #1         'increment counter
              mov     varbl,     nmbr       'make copy of counter
              sub     varbl,     #4  wz     'subtract final number
    if_nz     jmp     #do_again2            'if not final yet do again
    'the four differences are now in locations 6..9 in hub
              mov     nmbr,     #0          'reset couonter
              mov     mem0,     par         'reread mem0
              add     mem0,     #24         'mem0 is now location 6
              mov     stor,     mem0        '
              add     stor,     #20         'stor is location 6+5
              wrlong  zero,     temp3       'clear temp3
    'pointers are ready to read the four additions of speeds
    do_again3 rdlong  temp,     mem0        'read location from memory
              rdlong  temp2,    temp3       'read stored current total
              add     mem0,     #4          'increment mem location
              add     temp,     temp2       'add to total stored
              wrlong  temp,     temp3       'write new total
    if_nz     jmp     #do_again3            'if not final do again
              wrlong   temp, stor           'store final total
              shr     temp,     #2          'divide by 4
              add     stor,     #8          'add two mem locations to stor=13
              wrlong  temp,     stor        'store average at loc 13
              jmp     #Read_sig             'go back to beginning
    'park     jmp     #park                 'go into loop
    'subroutines
    wait_Hi   mov               temp4,    ina
              andn    temp4,    mask8 wz
    if_nz     jmp     #wait_Hi
    wait_Hi_ret ret
    Wait_lo   mov     temp4,    ina
    if_z      jmp     #wait_Lo
    Wait_lo_ret ret
    'constants and variables
    zero      long    0
    dira_set  long    %00000000_00000000_00000001_00000000
    mask8     long    %11111111_11111111_11111110_11111111
    mem0      res     1
    mem1      res     1
    temp      res     1
    temp1     res     1
    temp2     res     1
    temp3     res     1
    temp4     res     1
    stor      res     1
    Nmbr      res     1
    varbl     res     1
    Harprit.
    edited 2013-02-04 06:09
    Sure - I am very interested in seeing your code on a Dual Tach!
    Lv
    edited 2013-02-04 06:15
    Thanks, I will study this code and see how I do with it.
    Harprit wrote: »
    Harprit.
    Also, if you did not see it, check out the three axis cnc package put up by Don Starky. Stephanl mentioned it a couple days ago also.
