Is it possible??
I would like to do some lighting for my custom computer case, and I would like to have the BS2 control the LED’s. But I would like for them to be based on CPU frequency. What I mean is when the CPU is at idle (1.6GHz) the led’s would do a fade on, off pattern. But when the CPU boosts (4.5GHz) the led’s would do a different pattern.
Now making the BS2 do the patterns is already done, my problem is knowing how to read the frequency of the CPU, and how could I do it without doing anything to the CPU or the motherboard.
Thanks for your time and input.
Here is an example for getting CPU speed. I found it on the WEB
I think the fan speeds up when the CPU is running faster.
You would not need the BS2 to control the LEDs.
Another Idea.....
Monitor the power supply current. The higher the current the brighter the LEDs.
Thank you SRLM, I thought of doing that, but since my CPU is water cooled it would make it a little hard to get an accurate reading.
