Best way to write a Byte using PASM
I'm working on a parallel LCD interface driver. I want to write a byte to 8 contiguous pins.
I also want the driver to have the first pin be definable.
I'm just not sure what is the most efficient way to update all 8 lines at the same time.
I've tried the following code, but did not see any outputs change on my Logic Analyzer.
Here I define my vars...
Here is where I pass the first pin at the start up of the driver...
Then here is where I try to write a byte to the port...
Not sure what I'm doing wrong. Or maybe there is some better way to do this.
Jim Fouch
DB0 Res 1 DBMask Res 1 ' Used for Masking the out port Byte2Write Res 1
Mov Par_,Par ' Grab Par pointer
RDLong DB0, Par_
MOV DBMask, #$FF ' Create an 8 Bit Mask
SHL DBMask, DB0 ' Shift Left this many pins
OR DIRA, DBMask ' Define as an output
WriteByte ' This sub will write out 8 bits that are in Byte2Write
MOV Temp4, Byte2Write ' Place Byte to Write in
SHL Temp4, DB0 ' Shift Left to Align with DB0
ANDN OUTA, #DBMask ' Set OUTA using DBMask (make all pins Low)
OR OUTA, #TEMP4 ' Copy Byte2Write into Temp2
WriteByte_ret RET
Jim Fouch
SHL Temp4, DB0 ANDN OUTA, DBMask OR OUTA, Temp4Alternatively you could have:SHL Temp4, DB0 MOV Temp5, Temp4 XOR Temp5, DBMask ' Make complement of data ANDN OUTA, Temp5 ' Turn off any zero bits OR OUTA, Temp4 ' Turn on any one bitsI always seem to mess up on the #. Either forget it when I need it or put it there when I don't....lol
I'm stuck in airports or on an airplane for the next 10 hours, so I'll have to try soon as I get back to my lab.
SHL Temp4, DB0 AND OUTA, Temp4 ' Turn off any zero bits OR OUTA, Temp4 ' Turn on any one bitsNote that the AND will turn off other bits in OUTA (outside of the 8-bit mask). If no other OUTA bits are used in this cog, that won't be an issue. This will also work if another OUTA bit is only used as a 0->1->0 strobe so forcing it to zero at this point won't cause problems.
