Wierd behavior with VAR variable placement
lardom
I managed to get two cogs modify their variables without causing one cog to hang.
The rules for parallel processes I've learned include:
a) You can't share variables
b) Infinite loops do not return to the caller and can only by over-ridden by a cognew command
c) method calls must come from the launched cogs to preserve parallel processes
I have noticed unexplainable delays with the 'b / B' methods simply from where I position variables in the VAR block. Can anyone tell me what's going on?
CON
_clkmode = xtal1 + pll16x
_xinfreq = 5_000_000
{change pin from 6 to 7
removed variable references to A and object hung
removed 'stackA[40], period_a, and finally index---works
move A and B variables to separate lines-----works
duplicate B and change to A and see if it still works
B still works with A methods and variables added
A works alone and changed pin from 7 to 6 }
var
word cogB
word cogA
long stackB[10], period_b, indexB, stackA[10], period_a, indexA
' long stackA[10], period_a, indexA
pub start
stop_b
cogB := cognew(main_b(2), @stackB) + 1
stop_a
cogA := cognew(main_a(2), @stackA) + 1
PUB stop_b
if cogB
cogstop(cogB~ - 1)
PUB stop_a
if cogA
cogstop(cogA~ - 1)
pub main_b(V) | idx
dira[7]~~
period_b := clkfreq/V
repeat idx from 1 to 3
outa[7]~~
waitcnt(period_b + cnt)
outa[7]~
New_b
pub main_a(V) | idx
dira[6]~~
period_a := clkfreq/V
outa[6]~~
waitcnt(period_a + cnt)
outa[6]~
New_a
PUB New_b
indexB := indexB + 2
if indexB > 35
indexB := 2
main_b(indexB)
PUB New_a
indexA := indexA + 2
if indexA > 35
indexA := 2
main_a(indexA)
EDIT: Using idx by both cogs is not a problem since this is a stack variable, and each cog has it's own stack space.
Reality:
a) You can share variables, but you have to do it remembering that both cogs can change the variable at the same time and one cog can change a variable between two references to the variable in the other cog. In other words, A + A may not be the same as 2 * A.
b) Infinite loops do not return to the caller. When did they ever return to the caller? They can't be over-ridden by a cognew. The only way a cog in an infinite loop can be affected by another cog is to do a COGSTOP on that cog to reset it or do a COGINIT on that cog to force a new program to be loaded and executed or possibly modify a hub value referenced in the infinite loop (if it's written that way) to turn the infinite loop into an exiting loop.
c) A method call is done by a specific cog because that's the cog whose Spin interpreter is executing the call. There's nothing about preserving parallel processes. Each cog is a (mostly) separate computer that happens to be (interpretively) executing code in a memory that's shared by all the cogs. The interpretive code is read-only and can be simultaneously interpreted by more than one cog, each with its own data area (its stack). There's also a shared data area where you have to be careful about how the data is used.
Try to keep separate the ideas of objects and parallel processing. They're really orthogonal. You can have a program consisting of a single (main) object that uses all 8 Propeller cogs to do things. 7 of the 8 cogs can all be executing the same single method with the 8th cog executing the main program which can also call the same method once things are set up. You can also have a multi-object program with multiple levels of objects, all using only a single cog. There's no direct absolute relationship between the two concepts.
@Mike Green, I pay attention to what you say pretty closely. Lessons learned.
