non-destructive "expansion" of Propeller Servo Controller USB
Let's say, just for the sake of discussion, that I have one of these to start with:
http://www.parallax.com/Store/Microcontrollers/PropellerDevelopmentBoards/tabid/514/CategoryID/73/List/0/catpageindex/2/Level/a/ProductID/595/Default.aspx?SortField=ProductName%2cProductName
and I wanted to make use of P16-P23 (which I see on the schematic are not used for anything) so that I could get 8 more I/O lines to use. How would I go about doing this in a way that reduce the odds I would end up with a $40.00 brick?
PS I will be loading different firmware into the little beastie as well to take advantage of these "extra pins"
I concur.
The Parallax Range Finder has eight unused pins; while these pins aren't brought out to header pins, they are brought out to solder pads. The Propeller Servo Controller would have been much more appealing with access to the other I/O pins.
That said, there is nothing that says you can not make a harness up and add your own connections. From looking at the large image on the store page, the pins themselves are accessible with a bit of pad extending beyond the chip. Little #30 kynar wrap wire will solder nicely. If like me geezerhood is starting to set in on the eyes, you can always break out the 2.5x surgical loupes used by who else, surgeons or dentists....... Got mine, US Surgical Instruments 2.5x flip up (far better than the embedded ones my dentist uses, his opinion) for $50.00 on ebay from a dental student.
Frank
