Wheel solution for those cheap stepper motors?
Oldbitcollector (Jeff)
I was challenged by @Prof_Braino a while back to come up with a sub $20 robot that incorporated two of those cheap stepper motors, a bluetooth module, and an ultrasonic sensor. At the time I wasn't buying in enough volume to meet this challenge.... I am now.. I think a low-end robot is completely possible.
I've almost worked out a mounting base and the third position will be a tail dragger (or cheap caster wheel).
Where I'm stuck is trying to find a wheel that fits those motors. Has anyone seen anything that fits?
Jeff
Jeff
http://forums.parallax.com/showthread.php/138125-Erco-s-Figure-Eight-Challenge?p=1157894&viewfull=1#post1157894
They are 3D printed. The wheel itself is PLA, while the "rubber" is printed with soft PLA from Orbi tech.
Massimo
Here is a robot using the $3 stepper motors and a BOE. The chassis and wheels came from a toy truck at Goodwill for a couple bucks then I added a ping and a caster wheel completes it. Simple, cheap, fun and under $20 total not including the BOE
Whats the OD of the stepper motor shaft? ... If you don't have access to laser cutting, the "circle" cutting attachment for a dremel tool works nice. For the shaft connection I have found that a friction fit with 1/4 inch Polyvinyl "Aquarium tubing" works well.. especially if you use multiple acrylic disks stacked together for a single wheel.
...And for the size of wheel you would need, the Acrylic, Plexiglass, etc. can be FREE for the asking at your local hardware store since it would be considered scrap. I've hit up Ace, Home Depot, and Lowes before and all three have been very helpful when it comes to asking for their scrap material.
Grabbing my micrometer from the shop today.
Jeff
I was looking for a way to mount wheels on the stepper motors and ran across these hubs on eBay:
http://www.ebay.com/itm/STEPPER-MOTOR-PREDRILLED-ALUMINUM-HUBS-5-PCS-/120660614713?pt=LH_DefaultDomain_0&hash=item1c17eede39
I haven't bought them yet 'cuz I haven't been able to get the stepper motors to run. :-(
Amanda
@Amanda: How can we help you and your steppers? We've mentioned them in threads a fair amount (see below). Those cheap steppers come with a ULN2003 driver board only good for one stepper, but you can see the 2803 I used in my breadboard. Works a treat for both motors.
I will say that these steppers have clear limitations. They are not fast, they have enough backlash to frustrate, and they likely strip very easily. When you put a BoeBot -sized wheel on them, there's a tendency to grab the wheel and rotate/backdrive the stepper. I honestly haven't done that yet, but considering the fragile tiny teeth on the plastic gears inside, one twist might be the end of them. I did a teardown on one at http://forums.parallax.com/showthread.php/141149-3-Stepper-Motor-amp-Board?p=1144016&viewfull=1#post1144016
My quickie BS1 Stepper Bot: http://forums.parallax.com/showthread.php/142831-Old-School-Rapid-Prototyping?highlight=stepper+motor
Jeff
Being 2d a dxf profile maybe is the best solution.
If you don't mind posting it.. having a proven press fit profile would be nice.
Massimo
Some reasons that I have seen that cause vibration instead of motion: (1) cycling through the sequence steps too fast and (2) wrong wiring, (3) bad UNL2003 board, (4) wrong step sequence and (5) low battery for the motor.
+1
I was using a Stamp board, but I'll give your spin code a shot. (As well as verifying the other issues mentioned).
I know they're cheap, but I'd kinda expect one of them to work! :-[
Do a very slow step sequence (few Seconds between each pattern sequence) and check the leds light correcly (issues 2 and 4). this will also check bad wiring, broken connection, pin not working.
Use a working code.. the wrong pause in the sequence pattern makes the motor vibrate too.
http://www.pololu.com/catalog/category/24
That'll save me a little time in "recreating the wheel".
As soon as I finish a base and mounting solution for the motors I'll have something interesting to offer. Finally I'm ordering enough of the the product lines to offer competitive pricing on this stuff.
Jeff
Left to right :-
lego ....not cost effective
Playmobile :- cost effective
Wooden local hobbyshop with rubber "O" ring :- very cost effective and for me preferable.
I use a lego coupling link.... just a few snips and presto an interference fit that hold very well.
-Prophead
We have a growing army of these little stepper driven robots as I'm using them for 4-h projects this year. It will be fun to have some more code examples for the kids to see.
