Prop Quickstart with Human Interface Board
I have the BST software (using a Mac) and am totally new to Propeller programming, but when i load this code:
CON _clkmode = xtal1 + pll16x
_xinfreq = 5_000_000
SERIAL_BAUD = 115_200
CODES_PER_LINE = 32
DATA_PIN = 26 ' Should be pulled high to 3.3V with 10K resistor.
'As used on Demo Board
CLOCK_PIN = 27 ' Should be pulled high to 3.3V with 10K resistor.
OBJ
Term : "Parallax Serial Terminal"
Kb : "pedals"
PUB Start
'start the tv terminal
Term.Start(SERIAL_BAUD)
Term.Str(string("Pedals...", Term#NL))
'start the keyboard
Kb.Start(DATA_PIN, CLOCK_PIN)
'echo keystrokes in hex
repeat
repeat CODES_PER_LINE
Term.Char("$") ' hex indicator in Spin
Term.hex(Kb.Getkey, 4)
Term.Char(" ")
Term.Char(Term#NL)
and it says theres an error Term "Parallax Serial Terminal". whats this mean?
CODES_PER_LINE = 32
OBJ
Kb : "pedals"
PUB Start
'start the keyboard
repeat
Term.Char(" ")
Term.Char(Term#NL)
The object files have to be either in the same directory as your source file(s) or in the library directory which is set in one of the preferences windows.
[/B] and [B][/code ] [/B]blocks [I](without the spaces to get your entry to look like this...)[/I] [code] CON _clkmode = xtal1 + pll16x _xinfreq = 5_000_000 SERIAL_BAUD = 115_200 CODES_PER_LINE = 32 DATA_PIN = 26 ' Should be pulled high to 3.3V with 10K resistor. 'As used on Demo Board CLOCK_PIN = 27 ' Should be pulled high to 3.3V with 10K resistor. 'As used on Demo Board OBJ Term : "Parallax Serial Terminal" Kb : "pedals" PUB Start 'start the tv terminal Term.Start(SERIAL_BAUD) Term.Str(string("Pedals...", Term#NL)) 'start the keyboard Kb.Start(DATA_PIN, CLOCK_PIN) 'echo keystrokes in hex repeat repeat CODES_PER_LINE Term.Char("$") ' hex indicator in Spin Term.hex(Kb.Getkey, 4) Term.Char(" ") Term.Char(Term#NL)BST doesn't come with Parallax Serial Terminal.spin. Here's a copy.
I wish this was not the case. I installed PropTool on a school PC, and took the library home for my Mac.
As far as I know, the basic library isn't hosted anywhere.
