Wheel solution for those cheap stepper motors? — Parallax Forums
edited 2013-04-14 21:28 in General Discussion
I was challenged by @Prof_Braino a while back to come up with a sub $20 robot that incorporated two of those cheap stepper motors, a bluetooth module, and an ultrasonic sensor. At the time I wasn't buying in enough volume to meet this challenge.... I am now.. I think a low-end robot is completely possible.
I've almost worked out a mounting base and the third position will be a tail dragger (or cheap caster wheel).
Where I'm stuck is trying to find a wheel that fits those motors. Has anyone seen anything that fits?
Jeff
  • max72max72 Posts: 1,155
    edited 2013-01-17 00:30
    I posted one here:
    http://forums.parallax.com/showthread.php/138125-Erco-s-Figure-Eight-Challenge?p=1157894&viewfull=1#post1157894
    They are 3D printed. The wheel itself is PLA, while the "rubber" is printed with soft PLA from Orbi tech.
    Massimo
  • Prophead100Prophead100 Posts: 192
    edited 2013-01-17 20:03
    Here is a robot using the $3 stepper motors and a BOE. The chassis and wheels came from a toy truck at Goodwill for a couple bucks then I added a ping and a caster wheel completes it. Simple, cheap, fun and under $20 total not including the BOE
    1024 x 768 - 112K
    edited 2013-01-17 21:40
    Laser cut acrylic wheels on a stepper motor BoeBot!
    816 x 612 - 94K
    edited 2013-01-17 22:13
    Jeff,
    Whats the OD of the stepper motor shaft? ... If you don't have access to laser cutting, the "circle" cutting attachment for a dremel tool works nice. For the shaft connection I have found that a friction fit with 1/4 inch Polyvinyl "Aquarium tubing" works well.. especially if you use multiple acrylic disks stacked together for a single wheel.
    ...And for the size of wheel you would need, the Acrylic, Plexiglass, etc. can be FREE for the asking at your local hardware store since it would be considered scrap. I've hit up Ace, Home Depot, and Lowes before and all three have been very helpful when it comes to asking for their scrap material.
    edited 2013-01-18 06:50
    Agreed! I've already started down the path of cutting acrylic to create the wheels. @erco you don't happen to still have the specifics on that wheel do you?
    Grabbing my micrometer from the shop today. :)
    Jeff
  • ajwardajward Posts: 1,130
    edited 2013-01-18 07:13
    Those acrylic wheels are sweet!!!
    I was looking for a way to mount wheels on the stepper motors and ran across these hubs on eBay:
    http://www.ebay.com/itm/STEPPER-MOTOR-PREDRILLED-ALUMINUM-HUBS-5-PCS-/120660614713?pt=LH_DefaultDomain_0&hash=item1c17eede39
    I haven't bought them yet 'cuz I haven't been able to get the stepper motors to run. :-(
    Amanda
    edited 2013-01-18 09:15
    @Jeff: I have the wheel file in ai but can't attach here (invalid file type). Can get it in Rhino if you prefer. The wheel is a beautifully tight press-fit onto the stepper shaft. That's a BoeBot chassis, and since the stepper's offset output shaft is higher than the servos' shaft (visible in pic), I reduced the wheel diameter to keep the chassis level using the stock roller ball. But those are the stock BoeBot rubber bands on the wheels for traction.
    @Amanda: How can we help you and your steppers? We've mentioned them in threads a fair amount (see below). Those cheap steppers come with a ULN2003 driver board only good for one stepper, but you can see the 2803 I used in my breadboard. Works a treat for both motors.
    I will say that these steppers have clear limitations. They are not fast, they have enough backlash to frustrate, and they likely strip very easily. When you put a BoeBot -sized wheel on them, there's a tendency to grab the wheel and rotate/backdrive the stepper. I honestly haven't done that yet, but considering the fragile tiny teeth on the plastic gears inside, one twist might be the end of them. I did a teardown on one at http://forums.parallax.com/showthread.php/141149-3-Stepper-Motor-amp-Board?p=1144016&viewfull=1#post1144016
    My quickie BS1 Stepper Bot: http://forums.parallax.com/showthread.php/142831-Old-School-Rapid-Prototyping?highlight=stepper+motor
    edited 2013-01-18 09:17
    @ecro, or email it to me jeffledger (at that free email google runs). Do you mind if I use that file to have a few of these made for Propellerpowered?
    Jeff
    edited 2013-01-18 13:58
    Erco, you can post any file as long as you zip it.
    Being 2d a dxf profile maybe is the best solution.
    If you don't mind posting it.. having a proven press fit profile would be nice.
    Massimo
    edited 2013-01-18 14:59
    @erco Not sure what's up with them. I used your sample code which seemed to work quite well for you, but my motors just sort of vibrate without turning. :-|
    edited 2013-01-18 20:40
    If your trying to get the motor working, here is some simple code I was using for a BOE and $3 stepper robot....
    edited 2013-01-18 20:45
    ajward wrote: »
    Some reasons that I have seen that cause vibration instead of motion: (1) cycling through the sequence steps too fast and (2) wrong wiring, (3) bad UNL2003 board, (4) wrong step sequence and (5) low battery for the motor.
    edited 2013-01-18 22:04
    +1
    edited 2013-01-19 00:30
    I was using a Stamp board, but I'll give your spin code a shot. (As well as verifying the other issues mentioned).
    I know they're cheap, but I'd kinda expect one of them to work! :-[
    edited 2013-01-19 05:42
    Check Prophead100 suggestions. If all of them have the same issue probably 3 is not you case.
    Do a very slow step sequence (few Seconds between each pattern sequence) and check the leds light correcly (issues 2 and 4). this will also check bad wiring, broken connection, pin not working.
    Use a working code.. the wrong pause in the sequence pattern makes the motor vibrate too.
  • nightwingnightwing Posts: 56
    edited 2013-01-19 07:41
    If still looking for wheels and even tracks try here...
    http://www.pololu.com/catalog/category/24
    edited 2013-01-19 10:26
    Attached is a zipped file with the Adobe illustrator file of my wheel. Sure Jeff, make all you want. I tried patenting the wheel long ago, but they just laughed at me at the PTO...
    edited 2013-01-19 10:54
    Thank you @erco!
    That'll save me a little time in "recreating the wheel". :)
    As soon as I finish a base and mounting solution for the motors I'll have something interesting to offer. Finally I'm ordering enough of the the product lines to offer competitive pricing on this stuff.
    Jeff
  • GarethGareth Posts: 278
    edited 2013-01-19 12:45
    Here is what i use on my sub $20 dollar robots :-
    Left to right :-
    lego ....not cost effective
    Playmobile :- cost effective
    Wooden local hobbyshop with rubber "O" ring :- very cost effective and for me preferable.
    I use a lego coupling link.... just a few snips and presto an interference fit that hold very well.
    512 x 383 - 124K
    512 x 384 - 118K
    640 x 480 - 123K
    edited 2013-01-19 17:18
    If your cutting your own wheels, one thing to think about is matching the diameter to the step angle of the motor so that each step of the motor correlates to a precise distance. It can make navigation easier....
    edited 2013-03-15 21:38
    For those working on a stepper robot, here is my code for the line following "you've got mail" contest Sac Robotics is working on... It runs each motor in a separate cog with either 4 or 8 step cycles, runs a ping in another, serial comm in another, and the control loop in a final one. Doing the parallel processing leads to some interesting coordination such as when to wait for another wheel to do something.
    -Prophead
    edited 2013-03-16 19:36
    Thanks for sharing the code, Prophead!
    We have a growing army of these little stepper driven robots as I'm using them for 4-h projects this year. It will be fun to have some more code examples for the kids to see.
    I cleaned up the code and made this into an object. Not too fancy but it makes good use of the parallel aspects of the processor. I have used the object methods on the same robot for both line following and autonomous wandering in the house. You can see it following a line and dropping off a business card in a "You've Got Mail" Challenge at http://www.youtube.com/watch?v=yzIWk8r3IwQ
    800 x 600 - 37K
    1024 x 768 - 112K
