Question regarding Basic Stamp II and creating a simple tachometer
I like building things myself and that includes a CNC gantry Mill I've completed recently. I'd like to add a tachometer to the spindle so I can adjust the rpms with my variable speed controller. Is there a project description including schematic and code anywhere that can get me started? I'm fairly handy with electronics, but not and EE, so I'd probavbly need some specifics about the sensor ciircuit and interfacng the LCD readout. I think using a reflected IR sensor or a hall effect would do the trick and I only need a rpm update every couple seconds. However, I do need up to 30,000rpm capability. Has anyone published a project like this or is there info available where I can piece such a thing together? I'd like to use the BS2 since I know more about programming it than some of the others.
Thanks in advance for any help on this.
Keith
Keith
I found a section on "TACHOMETER" in one of the parallax text books on process control. This section should be some help. It depends if I have enough background to go out of the box and apply it to my specific application. However, it has given me a lot to chew on for the time being. Once I get a plan of attack I'll probably be back on the forum asking for more advice. Thanks for your help. I do appreciate it.
Keith
Keith
Keith
I used a photo transistor and white duct tape to register the counts.
I also used a 555 one-shot timer to eliminate false triggers.
For the light source, I used my 500 watt shop light pointed at the duct tape.
I hope this help you in some manner.
