12 LED Also used with 220VAC?
Recently I ordered from EBAY
10W High Power Bright White/Warm White 800-900LM DC12V Led light Lamp bead
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=321024520278&ssPageName=ADME:L:OU:US:3160
Instead of getting warm white, I received bright white.
Also, instead of being labeled "12v 3 watt" they were labeled "AC220-240V 3 Watt". I assumed somebody put the wrong sticker, but the email reply was:
So I take it they mean it can be connected directly to 220VAC mains current. I'm a little iffy about this. Do I understand this correctly? If it can work from 220VAC, can it also work from 120VAC mains? Will it be half as bright? The LED module is just an array of nine LEDs on an aluminum circuit board, there are no passives or IC that I can see.
I'm worried about the magic smoke getting out.
About the voltage , the LED chip can be used under AC220v or DC12v , there is no difference for the led chip about the working voltage . please trust us , we are professional and regular LED light manufacturer in China .
Why do I find that hard to believe?
Is the LED 'module' you have the same as the one in the ebay image?
Are there any identifying figures on the LED?
PS - wear eye safety
the magic smoke might come out -- there may be a snap-crackle-pop too....recommend the "most inside" this experiment is done is a garage (better outside imho)
When you get it, take a picture and post it. See if you can draw up a bit of a schematic, but I wouldn't count on it.
Hook it up to a Variac and monitor input current as the voltage is increased.
Cheers,
It's the one in the picture, only marks on its are the + and the - etched in the aluminum circuit board.
At 12 volts dc it draws 0.3 amp. It doesn't get warm, but I have it on a heat sink using the thermal grease that was applied top the back before shipping.
If that ali plate has nothing on it but LEDs I see no way it won't explode connected to 120/220 volts.
You may want to get one of these: http://dx.com/p/900ma-10w-power-constant-current-source-led-driver-85-265v-42745
