how to use python to communicate with the propeller
Hello,
I want to control a couple of servos using the PC and python 2.7.3.
I am using pySerial to perform serial communication with the propeller
For debugging, I have been trying to use just 1 servo.
This is the code on the propeller side:
[HTML]CON
_clkmode = xtal1 + pll16x 'Standard clock mode * crystal frequency = 80 MHz
_xinfreq = 5_000_000
pin = 14 'test servo pin
'width = 1000 'not used for the moment
delay = 300 'not used for the moment
OBJ
servo : "servo32v7"
pst : "parallax serial terminal"
PUB main | width
servo.start
'servo.ramp 'not used for now
pst.start(115200)
waitcnt(clkfreq*2+cnt) 'waits 2 seconds
repeat
width := pst.DecIn 'this gets a value between 500 and 2500 to move the servo to the desired position
servo.set(pin, width)
waitcnt(clkfreq+cnt)
[/HTML]
I think this code is fine, because if I connect to the propeller using the python miniterm tool and send values between 500 and 2500, the servo moves.
This is the python miniterm command I'm using:
[HTML] python -m serial.tools.miniterm -p COM6 -b 115200[/HTML]
As mentioned, with this tool, I can move the servo using the PC.
Now, when I try to do the same using a small python program, the program runs "fine", because I don't get an error, but the servo won't move. (so it's not fine:D )
This is the python code I'm using:
[HTML]import serial
import time
ser = serial.Serial()
ser.port = "COM6" # COM port on the laptop
ser.baudrate = 115200 # same baudrate specified in the propeller
ser.open() # opens port COM6
connected = ser.isOpen()
print "connected to the propeller? %s" % connected #confirms connection to the propeller port
print "a number between 500 and 2500: "
servoval = raw_input() #receives value (the problem might be after this line but not sure what is it
ser.write(servoval)
ser.close()[/HTML]
So, I run this little python program and the servo won't move.
If I do some testing on the python console, this is what I get:
[HTML]Python 2.7.3 (default, Apr 10 2012, 23:31:26) [MSC v.1500 32 bit (Intel)] on win32
Type "help", "copyright", "credits" or "license" for more information.
>>> import serial
>>> import time
>>> ser.open() #opens port COM6
>>> ser.write("2000")
4L
>>>[/HTML]
What does this "4L" means?
What am I missing here?
I have been looking for more information, but seems like other people has been using the same thing without any problems.
Any advice on how to debug what I am actually sending with python?
I appreciate any help.
Thanks.
-Tono
[HTML]CON
OBJ
servo : "servo32v7"
PUB main | width
servo.start
pst.start(115200)
repeat
[/HTML]
[HTML]import serial
import time
ser.write(servoval)
ser.close()[/HTML]
>>> import serial
>>> import time
>>> ser.write("2000")
4L
>>>[/HTML]
Thanks.
-Tono
Looking in the ParallaxSerialTerminal file under decIn, we have:
So, it looks like your problem will be resolved if you add a carriage return:
If you want to debug what you are sending with the Python script, I would get an FTDI based USB to serial converter (Prop plug or the like), and hook up it's RX line to the TX line that comes from the USB to serial that is connected to the Propeller. Open up a terminal on the new USB to Serial connector, and try sending data from your python program.
But then I tried:
[HTML]ser.write(servoval + '\r\n')
time.sleep(1.5)
#ser.write('\n')
ser.close()
[/HTML]
I had to add that pause and it seems to be working fine now.
Thanks for the tip
Or you use raw datatypes on propeller-side as well. This would improve transmission-speed, but you no longer have the possibility to attach with a terminal program and simply test the propeller code manually.
Once I added the '\r\n', I was able to move the servo.
I didn't try raw values... it could work as well, will test it and let you know if it works.
