Are servos choppy?
I tested servo control with a mini breadboard potentiometer using code I found in the OBEX. I couldn't get the servo to move smoothly and wondered if there was a problem with the pot, the code or the servo. Is that the way servos normally move?
Would need to look at the code, and your breadboard set up.
-Tommy
You should be able to get smooth motion from a servo. In post #9 of my 32 servo demo, I show how you can use an algorithm to give a servo a pendulum type of motion.
Sorry for the late response, I've been busy (working on a robot) over the last few days and I haven't been checking the forum much.
I saw the video of your hexapod and I thought "It looks alive!" You know your stuff.
What are you up to, Duane? Something sweet for Expo?
