The possiblity of a dual boot pad ==> Android and Linux
LoopyByteloose
Recently I got an Allwinner A10 board, a Cubieboard and was introduced to the possiblities of Google Android. It also runs several versions of Linux, which I prefer for projects.
Still, I am a bit wary of a touchpad that is only Android and I came across one that offered Android and Linux. Further investigation seem to claim that Windows8 and Android is possible as well.
So now I am on the prowl for a good dual boot pad for Android and Linux. Has anyone done this?
http://arstechnica.com/gadgets/2012/11/android-and-linux-on-a-dual-booting-tablet-for-100/
http://stream0.org/2011/11/24/dual-booting-android-and-linux-on-asus-transformer-part-two/
http://sven-ola.dyndns.org/repo/debian-kit-en.html
Mostly, Linux tablets of any sort are just beginning to appear.
http://www.zdnet.com/blog/open-source/spark-the-first-free-software-linux-tablet-is-on-its-way/10255
Anyways, i have an IPad and ache to be able to run whatever I want on it... and have a proper on-screen keyboard... that is the future of computing, iOS and similars, how did we allow it to happen?
@Loopy: the original tf101should not be too expensive anymore. Cheaper then an iPad at least
I am very curious if the tf101 touchpad with process Chinese input via the touch screen. I have tried keyboards and other devices. I have even learned Tsang Jie (Chinese speed touch typing), but just being able to write the characters is so much easier.
Ideally I'd be able to use Ubuntu and the touch screen to input Chinese directly, not have to poke around with a keyboard and either BPMF or Tsang Jie interface.
So far I only have had this on a PDA.
But it does seem that all the software is proprietary and not much has been done in LInux. Part of the shift to TouchPads has been to get away from public domain generic application availability. Private enterprise is trying to keep their revenue stream.
And so, I am very very curious to see if Linux will actually make its way into TouchPad platforms or the powers-that-be will shut it out.
-Tor
http://www.youtube.com/watch?v=k6k7vVxKxow
The demo is for Android on the Nexius 7, which behaves nicely. But I really cannot get any clarity on what happens when Linux is installed. This is really leading edge or beyond.
Not all Linuxes support Chinese and English, and those that do are often not a WYSIWYG interface.
I guess that if I get a pad of any sort, I might have to accept that won't be ideal in this aspect - a dual language touch screen in Linux where one language is NOT ascii-based.
I am attracted to the dual-boot, but have lots of experiece with actually using dual-boat and I find I generally stay in one OS for 99% of the time. I'd like it to be Linux.
http://tegaki.org/
Has not been updated for quite some time though
All distros support Chinese, it is just a matter of installing the right SW and set the right encoding.
There may be quite a bit of work getting the touch screen input acceptable to application, but it is a start. Personally I am not concerned about the Japanese or a Korean interface -- just Chinese and mainly Traditional Chinese.
I've pretty much reached the conclusion that while a Linux and Android dual boot is possible, the Linux user is going to have to do some real work to get the most out of the pad.
My Cubieboard runs Android and Linux in somewhat of a dual boot, but the Ubuntu Linux is much slower. In other words, Android has optimized while the Linux is rather generic and not fully able to exploit the hardware in the Allwinner A10. I am suspecting this situation extends into existing Pad platforms.
Perhaps, though, the Android has better drivers for the GPU on those Allwinners.
