BST w/ Linux Mint No propeller found
Hi all,
I have recently installed Linux Mint on a dual core celeron Zbox in my man cave, and am having an issue with BST detecting the propeller. I am by no means a Linux power user, but am getting the hang of it, slowly. There are number of threads and other sources that describe similar issues, but no solution has been found yet. If anyone has a good resource or advice to share I would be very grateful.
Here are some details.
* other usb devices work just fine, I have tried multiple propeller boards, BST returns "no propeller detected"
* manually selecting the "/dev/ttyUSB0" port in BST returns the same error
* ttyUSB0 does appear in /dev when the propeller is connected and disappears when i disconnect it.
* libftdi1 and libftddipp1 have both been reinstalled
* when i run lsusb from a terminal window i see the FTDI device as :
"BUS 03 Device 2 0403:6001"
* ls -al /dev/ttyUSB* returns
crw-rw---- root dialout 188, 0 Jan 13 -8:10 /dev/ttyUSB0
* cat /proc/tty/driver/usbserial returns:
usbserinfo:1.0 driver:2.0
0: module:ftdi_sio name:"FTDI USB Serial Device" vendor:0403 product:6001 num_ports:1 port:1 path:usb-0000:02:00.0-2
Thanks for any advice.
What is on the other end, which Propeller board?
I have had trouble in the past with bad USB cables, specifically those thin stretchy ones with the spool in the middle.
I would be tempted to try finding the Prop with HomeSpun and/or SimpleIDE just as a check.
http://propeller.wikispaces.com/Homespun+Spin+Compiler
https://sites.google.com/site/propellergcc/documentation/simpleide
The only other issue that I've had was that I had to sudo chmod 666 /dev/ttyUSB* to give myself permission to access the port. This was before I added myself to the dialout group (as Heater suggested), and may be Ubuntu specific.
I assume that if you open up a terminal program (cutecom, minicom, etc.) that you can connect to USB0? If you have a Prop plug, I'd make a loopback by putting a resistor (~10Kohm) between RX and TX, and using cutecom to make sure that you can communicate through the USB port.
I am a member of the dialout group, and homespun compiles the spin file just fine:
Homespun Spin Compiler 0.31
parsing Blinker2.spin
compiling Blinker2.spin
writing 32768 bytes to Blinker2.eeprom
I will give SimpeIDE a shot as well. I had this all working on a puppy linux once. That was different hardware though. There could be something funky in the zantec bios I suppose. Out of ideas here, and (as a windows user) feeling a bit annoyed with linux.
SRLM good advice thank you! I will give propGCC a shot as well. I do have a prop plug and I like that idea very much! Will indeed give it a shot.
The last thing i did was apply the permissions to ttyUSB0 via the command prompt. I had added my user to the dialout group earlier via the permissions desktop gui, at least i thought i did that correctly... good grief. Thanks for both for the input. I have a lot to learn about Linx it seems, but I least i can keep spinning!
When you add yourself to dialout (or any group), you have to restart for it to take effect.
