PropPlug on QS — Parallax Forums
PropPlug on QS
MacTuxLinMacTuxLin Posts: 821
edited 2013-01-02 04:30 in Propeller 1
I had to de-solder pin 3 & 12 on the quad-buffer to get this to work. Are there any simpler way than this?
  • MagIO2MagIO2 Posts: 2,243
    edited 2013-01-02 02:04
    I don't understand why you want to replace the buildin FTDI with a propeller plug?!
    But a better solution would be to add a switch/pulldown to the pins 1,4,10,13. This way you can set the whole quad-driver to tristate when you wan to use the propeller plug and set it back to normal operation if you don't have the prop-plug in place. So, in fact it is not simpler, but more usefull.
  • MacTuxLinMacTuxLin Posts: 821
    edited 2013-01-02 02:22
    Thanks. Yes, when reading its datasheet, it did crossed my mind but I was just thinking of a simpler process for now.
    The main purpose for this will be better understood when a new thread on a new project is publish by msrobot.
    edited 2013-01-02 04:09
    I'd do it like this:
    The 2 red lines (1 close to the via, one close to the cap) mean cut the line. Then de-solder pin 14. The green line is a wire which connects the de-soldered pin 14, the cap and the via.
    Pin 1 can then be connected with the switch/pullup.
    This will fix your QS ;o)
    316 x 195 - 48K
    Ah, I see it & this a clever alternative! Thanks!
    Will link to this thread later.
