Swiss Cheese PCB
I am trying to understand the "shotgun" effect on this PCB in certain areas. Specifically, how are the hole locations determinef and why do they go all the way thru? I thought a bunch of thru hole vias cause all sort of rf loop and other issues. Someone explain?
EDIT: I was looking at the picture again and I think I mis-understood your question. If you are referring to the vias in the ground planes, it is typically done to reduce RF or ground loops by creating a more consistent ground plane. I assume there is a PCB antenna at the left edge of the board?
http://www.support.wdv.com/Electronics/Fab/PCB%20Layout/HighSpeedPCBLayout.pdf
the antenna joins the board is the point with the highest RF currents will flow, so lots of copper will reduce resistance losses and allow the antenna to have a higher Q.
The vias are large (but not that huge as it's a close up), maybe is due to the minimum hole size that pcb manufacture could handle.
Of course holes need to be drilled and then filled with conductive ink and plated.
Really tiny holes ending most of the time being filled while being plated.
Electricity don't need solid planes to function good, just a like a Faraday cages have a lot of holes its still protects the person inside.
