Need help. Trouble connecting to the RFID RW board #28440
Hi
I am using a USB to Serial converter TTL-232RG5V to connect from my laptop to the the RFID RW module. TXD is connected to SIN & RXD is connected to SOUT. The VCC is 5V. The serial connector shows up as COM3 on my laptop but when I try to run the identify command from the STAMP interpreter, it does not look like the RW module is detected. So I am unable to download the BASIC stamp2 program also.
What am I doing wrong. I have looked at the signals on a scope also and when I send the refresh command in the identify program, I can see the SIN pulled down low for 100mS and then I see a 8 bit data transmitted (250us/databit). But nothing on the SOUT line.
Please help.
Please help.
