button that has push on/off
I have searched, even looked at the obex. If I missed it, please point me to it.
But not found code to make a toggle method that 1 button is used to toggle a output.
Example, push it ounce and it turns on a led, push it again and it turns off the led.
thanks,
stilgar
thanks,
stilgar
Each time the button is pressed you execute the line below.
If the pin is high it will go low, if low it will go high
pub debounce(pin, state, ms) | mstix, cycles, t dira[pin] := 0 ' force to input if (state) state := 1 ' force to 0 or 1 mstix := clkfreq / 1000 cycles := 0 ' clear cycles count t := cnt ' sync timing repeat ms waitcnt(t += mstix) ' wait 1ms if (ina[pin] == state) ' in active state? ++cycles ' yes, bump counter else cycles := 0 ' no, clear counter if (cycles == ms) return true else return falseif (debounce(TRIGGER, 1, 100)) !outa[LAMP] pause(150)I have a question for you (again). We discussed this earlier but I need more assurance.
Does a switch not make multiple connections on both the make and break condition.
If this is the case don't we need two delays as follows:
detect make
wait
detect break
wait
to get it right
I am about done with the PASM book and would like to really clarify this, for the beginners, in the book.
H
H
In both Spin and PASM I use a loop that reads the state of the switch and returns the state after it has remained the same x number of times through the loop.
I think this needs 4 total delays for one complete cycle
Am I right?
H
Based on your first post and this question I am assuming you have:
- A push button on a prop pin that closes a contact when it is pressed and opens the contact when released.
- A led on another prop pin that each time the button is pressed you turn on if it was off, or off if it was on.
You only need to:
detect make
wait
detect break
wait
if led is on turn it off
else turn led on
H
'PropBASIC code DEVICE P8X32A, XTAL1, PLL16X FREQ 80_000_000 LED PIN 1 OUTPUT PB PIN 2 INPUT OSAD VAR LONG = 0 'One Shot And Debounce PROGRAM Start Start: Do If PB = 1 Then If OSAD = 0 Then Toggle LED Endif OSAD = 1000000 Else If OSAD >0 Then Dec OSAD Endif Endif 'I can keep executing other stuff because the PB doesn't hold me up Loop ENDI agree, not usually good to halt the loop. I did not want to make the answer any more complicated than necessary.
I have a small routine that reads in all the switches once each time through the loop, debounces them, and sets the switch variable to the proper state once they are debounced. Any routine that needs to check the switch status reads the appropriate bit of the variable for the state of that switch.
Unfortunately, this doesn't accomplish what the OP wants. The LED won't latch in this case. All it does is have the output equal the state of the input.
Mickster
This code has the debounce period at the end of the routine. Most programmers place the debounce period at the beginning of the routine. Normally open switches don't randomly push themselves down so if the button is sensed down it's because it was pressed down by the operator. The delay of 1/16 second will work for most switches and can be shortened or lengthened to suit to type of switch and your needs. Military specification switches are very reliable but they can bounce around for what seems like ages before finally settling down.
start read system clock frequency Button1 test for Button1 down if not down jump to Button2 Output1 := not Output1 debounce by waiting 1/16 of a second (clock frequency shift right 4) wait for button up debounce by waiting 1/16 of a second (clock frequency shift right 4) Button2 test for Button2 down if not down jump to start complete some action debounce by waiting 1/16 of a second (clock frequency shift right 4) wait for button up debounce by waiting 1/16 of a second (clock frequency shift right 4) jump to startThe problem is that it can repeat too quickly and look like it's not latching...
It's not really a debounce. Touchpads don't "bounce" inthe traditional sense.
A quarter second delay at the top of the loop helped settle it down.
That could be other code, of course, but for a demo (shrug)...
TOTO.SPIN
CON { Toto - Touch On/Touch Off } _CLKMODE=XTAL2 _xinfreq = 5_000_000 VAR LONG MS001 , Lstate[8] Byte Buttons OBJ button: "QS_Button13" ' touchpad driver PUB Toto | B ' local variable B MS001 := CLKFREQ / 1_000 ' define 1 millisec button.start( @Buttons ) ' send address of Buttons Repeat B from 0 to 7 ' initialize all off LState[B] := 0 ' Repeat ' main loop waitMS(250) ' short delay to slow autorepeat Repeat B from 0 to 7 ' scan all buttons if Buttons & |< B ' button pressed? if LState[B] == 0 ' toggle associated LState LState[B] := 1 else LState[B] := 0 ' ' next, display results Repeat B from 0 to 7 ' show states for all if Lstate[B] ==1 TurnON(B+16) else TurnOFF(B+16) PUB WaitMS(W) ' wait for W milliseconds WaitCNT (W*MS001+cnt) PUB TurnON(pin) dira[pin] := 1 outa[pin] := 1 PUB TurnOFF(pin) dira[pin] := 1 outa[pin] := 0Touchpad driver:
'CON { QS_Button13.spin } ' { returns buttons packed bitwise in a single byte} VAR LONG ButtonAdr, ButtonCog, decay LONG Stack[ 16 ] ' define my stack PUB start( BAdr ) ' start this in a new cog ButtonAdr := BAdr ' save address of return byte if ButtonCog ' did the new cog start? cogstop(ButtonCog-1) ' OOPS! no cog available ButtonCog := cognew(ButtonScan, @Stack) + 1 decay := 4*(clkfreq/1000) PUB ButtonScan | B, B1 ' local variables dira [0..7] := 111111 ' all pad pins outputs outa [0..7] := 111111 ' all pad pins high 'main loop - scan the buttons Repeat ' loop forever Repeat B from 0 to 7 ' QS LEDS are pins 0-7 dira [B] := 1 ' make pin an output dira [B] := 0 ' make pin an input waitcnt(decay+cnt) ' short delay for some decay B1 := ina[B] ' read the pad if B1 == 0 ' 0 here means pressed BYTE[ButtonAdr] |= |< B ' set bit if pressed else BYTE[ButtonAdr] &= !|< B ' clear bit if not
