How to record, store and replay IR signals from a remote control - Page 2 — Parallax Forums
2»
  • JBWolfJBWolf Posts: 405
    edited 2012-12-29 14:55
    Ah I see those are the prop clip pins for PST.
    Ok here is the SIRCS output for the 3 buttons I need
    15 :: 11011001.0011010
    15 :: 11011001.0011011
    15 :: 10111001.0010101
    How do I go about replaying these?
    edited 2012-12-29 16:48
    I really like the MagicIR code structure.... I'm going to see if I can modify it to output the IR code in PST so I can copy to a text file and add then it to DAT variable arrays.
    I think once that is done it will be pretty straightforward to cannibalize the 'Playcode' to use for replay.
  • JonnyMacJonnyMac Posts: 9,649
    edited 2012-12-29 18:30
    Did you read this article?
    -- http://www.parallax.com/Portals/0/Downloads/docs/cols/nv/prop/col/nvp4.pdf
    If not, give it a go as it explains and provides full source code for receiving (which you seem to have sorted) and transmitting. In short, RX and TX are handled with separate objects. The objects are proven, having been used in the DEFCON badge that Parallax produced this year.
    You can find source code for that article here:
    -- http://www.parallax.com/Portals/0/Downloads/docs/cols/nv/prop/code/nvp4.zip
    edited 2012-12-30 04:04
    No I did not see the pdf doc before or have the sircstx code... I just had the rx code.
    That did it!, was able to get it working less than 15 mins after downloading.
    Very easy to use! I Like it!
    Thanks so much for the help. This turned out to be quite a bit more difficult to code from scratch than expected.
    So nice to get good help when needed, I sincerely appreciate it :)
