Changing variable value over time
Hi everybody,
I'm working on a project in which I control a VCA with the prop. I'm trying to introduce an attack- and releasetime in which the prop changes the control voltage (for the vca).
Here's how my code looks now:
CV is the variable which is written to the adc and controls the VCA. It's standard value is 3093. What I need is a little piece of code which changes the CV-value from 3093 to a calculated value (which is already calculated with the formula in the code above) over a time between 1ms and 1000ms (the releasetime, the releasetime-value is written in the variable RTIME). Afterwards, if the first if-condition which leads to a return (not the last two) is true, CV has to change back from the calculated value to 3093 in a time between 1ms and 200ms (the attacktime, ATIME). The calculated value from CV can be between 0 and 4095.
I tried a lot of things already but it just won't work... Does anybody has any hints on how to program the attack- and/or releasetime in this code?
Jasper
PRI Expander
ADYN := 1
if EHOLD > 0
waitcnt ((EHOLD * (Clkfreq / 1000)) + cnt)
Repeat
CV := 3093 + (OutCon * EGAIN) + (OutCon * (((RMSdB - ETRHD) * ERTIO) - (RMSdB - ETRHD)))
ADin := AD.in(1)
RMSdB := ((ADin - 3280) / InCon)
REDdB := (-(3093 - CV) / OutCon)
if (ADin > ((InCon * ETRHD) + 3280)) and (ADYN == 1)
ADYN := 4
Return
if (ADin =< ((InCon * GTRHD) + 3280)) and (ADYN == 1) and (GBP == 1)
Gate
Return
if (EBP == 0) and (ADYN == 1)
ADYN := 4
Return
Jasper
I found it difficult to follow the logic of your code.
The reasons are
- you didn't posted your complete code
- the variablenames are not selfexplaining
So I wrote some code from scratch wich does what you described in your post.
You need to diffentiate on two cases
difference between start and endvalue is bigger / smaller than the time in which the endvalue should be reached.
below working code that shows a demo on Parallax Serial Terminal (F12)
that gives you feedback what values the content of variable ActualValue has in each loop
just as a first hint
CON _clkmode = xtal1 + pll16x _xinfreq = 5_000_000 OBJ PST : "Parallax Serial Terminal" VAR long StartValue long EndValue long ActualValue long Diff long unsignedDiff long SignOfDiff long DeltaDiff long DeltaTime long ChangeTime long WaitTime byte MyStr[10] PUB Main Pst.Start(115_200) repeat ChangeTime := 1000 'milliseconds StartValue := 3000 EndValue := 3200 ActualValue := StartValue Diff := EndValue - StartValue unsignedDiff := ||Diff TaggedVal(string("Start: "),StartValue,true) TaggedVal(string("End: "),EndValue,true) TaggedVal(string("Diff: "),Diff,true) TaggedVal(string("unsignedDiff: "),unsignedDiff,true) IncDecVal ChangeTime := 1000 'milliseconds StartValue := 3200 EndValue := 3000 ActualValue := StartValue Diff := EndValue - StartValue unsignedDiff := ||Diff TaggedVal(string("Start: "),StartValue,true) TaggedVal(string("End: "),EndValue,true) TaggedVal(string("Diff: "),Diff,true) TaggedVal(string("unsignedDiff: "),unsignedDiff,true) IncDecVal ChangeTime := 100 'milliseconds StartValue := 400 EndValue := 200 ActualValue := StartValue Diff := EndValue - StartValue unsignedDiff := ||Diff TaggedVal(string("Start: "),StartValue,true) TaggedVal(string("End: "),EndValue,true) TaggedVal(string("Diff: "),Diff,true) TaggedVal(string("unsignedDiff: "),unsignedDiff,true) IncDecVal PUB IncDecVal 'if unsignedDiff is smaller than Changetime the time to increment / decrement the value 'is bigger than 1 millisecond if unsignedDiff < ChangeTime DeltaTime := ChangeTime / unsignedDiff 'So the waittime must be set to the apropriate time if Diff > 0 DeltaDiff := 1 'the increment per loop must be set to 1 else DeltaDiff := -1 'the decrement per loop must be set to 1 'if unsignedDiff is bigger than Changetime the time to increment / decrement the value 'is 1 and the inc /dec is bigger than 1 else DeltaTime := 1 'waittime is one millisecond DeltaDiff := Diff / ChangeTime 'increment per loop must be set to apropriate value PST.Str(string("DeltaTime: ")) PST.Dec(DeltaTime) PST.CHar(13) PST.Str(string("DeltaDiff: ")) PST.Dec(DeltaDiff) PST.CHar(13) PST.Str(string("Press Key to continue")) PST.StrIn(@MyStr) repeat (Diff / DeltaDiff) WaitCnt( (CLkFreq / 1000) * DeltaTime + cnt ) ActualValue := ActualValue + DeltaDiff PST.Dec(ActualValue) PST.CHar(13) PUB TaggedVal(StrPointer,Value,LineFeed) PST.Str(StrPointer) PST.Dec(Value) if LineFeed PST.CHar(13)best regards
Stefan
you should not have started a new thread! The old one gives a lot more informations about your problem. Especially the part where I told you that it does not make sense to increase CV more often than your other COG can send the value to the DAC!
