Need source for very quiet motors and omni wheels
I have been tasked with putting together a small robot that operates as quietly as possible. Silent would be ideal. I'm looking for some input as to which are the absolute quietest running gear motors. They need to be small: 20 to 50 oz-in torque and run about 120 rpm.
I have also been trying to find some small omni wheels. The problem is that they all seem to have either plastic or hard rubber rollers. If someone could point me to some 40 to 50 mm dia. omni wheels with soft rubber or foam rollers I would be very grateful.
Those are semi soft rubber rollers, you'll need to do a little extra gluing or something to make them really stay together well, but they work decently enough.
Not sure how you are going to get small motors that are also quiet. Usually small equals loud in my experience with motors. The big worm worm gear motors parallax sells with the 12v wheel/motor kit are super quiet... probably way too big though.
Roy
Motor mounting (rubber) and chassis design & material might be more important than motor selection, noise-wise.
So who are you trying to sneak up on?
Rich, I'd be surprised if you don't know about Vex's omni wheels. They use the same green rubber on the omni wheels as they do on their Mecanum wheels. I'm guessing this isn't soft enough for your needs. I've used their 4" wheels, they also have some nice 2.75" omni wheels. I'm guessing they're too big and too hard.
One of our forum members pointed out these omni wheels. I'm not sure if you (Rich) have seen them.
Roy, you need to get yourself a set of Vex's Mecanum wheels. They're much nicer than the FingerTech wheels. Have you seen Rich's robot with the Vex Mecanum wheels? (It's very cool.)
@Duane, We have tons of those Vex wheels at the robotics club. I need them to be less than 60mm diameter so that leaves out all of the Vex offerings.
@Roy, thanks, that will be helpful. I've been doing the same thing here but my selection of small motors is pretty unspectacular.
@erco, it will be moving in a very quiet environment where audio is being recorded, no sneaking. Nothing earth shattering - but my customer would not appreciate me talking about it.
I already have a set of the Vex ones, and yes, I saw Rich's bot with them at the expo.
erco,
Yeah they are kind of Smile, but I was able to make them function, and they were fairly quiet. They come apart if you just leave them press fitted together, but some glue would solve that. I definitely wouldn't put them under heavy load either.
I have code for controlling a three wheeled omni bot, so if your robot is going to use three wheels and you'd like to see/use my code, let me know.
I wonder if you'd have better luck finding a quiet motor/gearbox, if you use a motor with much more power than you need and just run it slow? (Just a guess.)
Peter
36mm Omniwheel
http://www.thingiverse.com/thing:705
