Parallax 2x16 Serial LCD Backlit, with Speaker #27977-RT
Hello everyone,
I just bought the subject item at Fry's Electronics:
http://www.frys.com/product/6726995;jsessionid=jChdtuzzoKANrd8+LpeFyQ__.node2?site=sr:SEARCH:MAIN_RSLT_PG.
Ardunio example:http://learn.parallax.com/kickstart/27977
Decimal Command Codes:http://www.parallax.com/Portals/0/Downloads/docs/prod/audiovis/27976-7-9-ParallaxSerialLCD-v3.0.pdf
Musical Notes:http://forums.parallax.com/showthread.php?139362-Parallax-2x16-Serial-LCD-(27977)-Backlit-w-Spkr-Example-Prop-snd-SPIN-code
I was able to make a Happy Birthday song by doing the following.
MY FIRST QUESTION: Does anyone know or have suggestions of an easier way of doing steps 2 and 3?I was unable to figure out how to set the length of a note to 3/16 or 3/4.
Here's the list I found, as noted in the link above for Decimal Command Codes:
Dec Hex Action
208 D0 Set note length to 1/64 note
209 D1 Set note length to 1/32 note
210 D2 Set note length to 1/16 note
211 D3 Set note length to 1/8 note
212 D4 Set note length to 1/4 note
213 D5 Set note length to 1/2 note
214 D6 Set note length to whole note (2 seconds)
MY SECOND QUESTION: Does anyone know how to set the length of a note to 3/16 and 3/4?
Code and image below:
- Mfr: PARALLAX
- Parallax Model: 27977-RT
- FRYS.com #6726995
- UPC: 644890279773
- Found the musical notes for the song on the internet. http://www.8notes.com/scores/1110.asp
- Converted the notes to decimal command codes (both lenghth and tone) (see image below).
- Typed it into the Arduino IDE (see code below).
- Uploaded to the Arduino UNO.
Dec Hex Action
[COLOR=#000000][FONT=courier new]const int TxPin = 6;[/FONT][/COLOR]
[COLOR=#000000][FONT=courier new]#include <SoftwareSerial.h>[/FONT][/COLOR]
[COLOR=#000000][FONT=courier new]SoftwareSerial mySerial = SoftwareSerial(255, TxPin);[/FONT][/COLOR]
[COLOR=#000000][FONT=courier new]void setup() {[/FONT][/COLOR]
[COLOR=#000000][FONT=courier new] pinMode(TxPin, OUTPUT);[/FONT][/COLOR]
[COLOR=#000000][FONT=courier new] digitalWrite(TxPin, HIGH);[/FONT][/COLOR]
[COLOR=#000000][FONT=courier new] mySerial.begin(9600);[/FONT][/COLOR]
[COLOR=#000000][FONT=courier new] delay(100);[/FONT][/COLOR]
[COLOR=#000000][FONT=courier new] mySerial.write(12); // Clear [/FONT][/COLOR]
[COLOR=#000000][FONT=courier new] mySerial.write(17); // Turn backlight on[/FONT][/COLOR]
[COLOR=#000000][FONT=courier new] delay(5); // Required delay[/FONT][/COLOR]
[COLOR=#000000][FONT=courier new] mySerial.print("Happy Birthday"); // First line[/FONT][/COLOR]
[COLOR=#000000][FONT=courier new] mySerial.write(13); // Form feed[/FONT][/COLOR]
[COLOR=#000000][FONT=courier new] mySerial.print("Happy Birthday"); // Second line[/FONT][/COLOR]
[COLOR=#000000][FONT=courier new] mySerial.write(216); // Select the 4th scale (A = 440Hz)[/FONT][/COLOR]
[COLOR=#000000][FONT=courier new] /* [/FONT][/COLOR]
[COLOR=#000000][FONT=courier new] Scale A A# B C C# D D# E F F# G G#[/FONT][/COLOR]
[COLOR=#000000][FONT=courier new] 4 440 466 494 523 554 587 622 659 698 740 784 831 [/FONT][/COLOR]
[COLOR=#000000][FONT=courier new] */[/FONT][/COLOR]
[COLOR=#000000][FONT=courier new]//1[/FONT][/COLOR]
[COLOR=#000000][FONT=courier new] mySerial.write(211); // 1/8 note (this should be 3/16, but I don't know the set length command for it)[/FONT][/COLOR]
[COLOR=#000000][FONT=courier new] mySerial.write(223); // C tone[/FONT][/COLOR]
[COLOR=#000000][FONT=courier new]//2 [/FONT][/COLOR]
[COLOR=#000000][FONT=courier new] mySerial.write(210); // 1/16 note [/FONT][/COLOR]
[COLOR=#000000][FONT=courier new]//3 [/FONT][/COLOR]
[COLOR=#000000][FONT=courier new] mySerial.write(212); // 1/4 note[/FONT][/COLOR]
[COLOR=#000000][FONT=courier new] mySerial.write(225); // D tone[/FONT][/COLOR]
[COLOR=#000000][FONT=courier new]//4 [/FONT][/COLOR]
[COLOR=#000000][FONT=courier new]//5[/FONT][/COLOR]
[COLOR=#000000][FONT=courier new] mySerial.write(212); // 1/4 note [/FONT][/COLOR]
[COLOR=#000000][FONT=courier new] mySerial.write(228); // F tone [/FONT][/COLOR]
[COLOR=#000000][FONT=courier new]//6[/FONT][/COLOR]
[COLOR=#000000][FONT=courier new] mySerial.write(213); // 1/2 note [/FONT][/COLOR]
[COLOR=#000000][FONT=courier new] mySerial.write(227); // E tone [/FONT][/COLOR]
[COLOR=#000000][FONT=courier new]//7[/FONT][/COLOR]
[COLOR=#000000][FONT=courier new] mySerial.write(211); // 1/8 note (this should be 3/16, but I don't know the set length command for it) [/FONT][/COLOR]
[COLOR=#000000][FONT=courier new] mySerial.write(223); // C tone [/FONT][/COLOR]
[COLOR=#000000][FONT=courier new]//8[/FONT][/COLOR]
[COLOR=#000000][FONT=courier new]//9[/FONT][/COLOR]
[COLOR=#000000][FONT=courier new]//10[/FONT][/COLOR]
[COLOR=#000000][FONT=courier new]//11[/FONT][/COLOR]
[COLOR=#000000][FONT=courier new] mySerial.write(230); // C tone [/FONT][/COLOR]
[COLOR=#000000][FONT=courier new]//12[/FONT][/COLOR]
[COLOR=#000000][FONT=courier new]//13[/FONT][/COLOR]
[COLOR=#000000][FONT=courier new]//14[/FONT][/COLOR]
[COLOR=#000000][FONT=courier new] mySerial.write(217); // Select the 5th scale (A = 880Hz)[/FONT][/COLOR]
[COLOR=#000000][FONT=courier new] 5 880 932 988 1047 1109 1175 1245 1319 1397 1480 1568 1661 [/FONT][/COLOR]
[COLOR=#000000][FONT=courier new]//15[/FONT][/COLOR]
[COLOR=#000000][FONT=courier new]//16[/FONT][/COLOR]
[COLOR=#000000][FONT=courier new] mySerial.write(220); // A tone [/FONT][/COLOR]
[COLOR=#000000][FONT=courier new]//17[/FONT][/COLOR]
[COLOR=#000000][FONT=courier new]//18[/FONT][/COLOR]
[COLOR=#000000][FONT=courier new]//19[/FONT][/COLOR]
[COLOR=#000000][FONT=courier new] mySerial.write(225); // D tone [/FONT][/COLOR]
[COLOR=#000000][FONT=courier new]//20[/FONT][/COLOR]
[COLOR=#000000][FONT=courier new] mySerial.write(222); // B tone [/FONT][/COLOR]
[COLOR=#000000][FONT=courier new]//21[/FONT][/COLOR]
[COLOR=#000000][FONT=courier new]//22[/FONT][/COLOR]
[COLOR=#000000][FONT=courier new]//23[/FONT][/COLOR]
[COLOR=#000000][FONT=courier new]//24[/FONT][/COLOR]
[COLOR=#000000][FONT=courier new] mySerial.write(230); // G tone [/FONT][/COLOR]
[COLOR=#000000][FONT=courier new]//25[/FONT][/COLOR]
[COLOR=#000000][FONT=courier new] mySerial.write(213); // 1/2 note (this should be 3/4, but I don't know the set length command for it) [/FONT][/COLOR]
[COLOR=#000000][FONT=courier new] delay(3000); // Wait 3 seconds[/FONT][/COLOR]
[COLOR=#000000][FONT=courier new] mySerial.write(18); // Turn backlight off[/FONT][/COLOR]
[COLOR=#000000][FONT=courier new]}[/FONT][/COLOR]
[COLOR=#000000][FONT=courier new]void loop() {[/FONT][/COLOR]
Do be aware that while there may be forumistas here that understand the Arduno language, we're primarily Parallax-oriented.
That may have the information you're looking for.
The little module =is= fun to play with!
