Current to a Prop input?
A device using an optofet switch requires that the current through the switch does not exceed 100mA. On a 5VDC 2amp supply, connected to the opto switch, then out of the switch into a 1k resistor to a Prop input pin, can someone please advise on how to calculate if this meets the requirements? I assume an input to be negligible, but wanted to see if there was any documentation.
Thanks.
The device specs are below:
Solid-state-relay (potential and polarity free)
Max. contact current: 100 mA
Max. contact voltage: 42 V AC/DC
Thanks.
If you are using a 10k pull-up/down then you are using a tiny more.
But if you are giving the prop a 5v signal, then current through protection diode is another thing.
So use pull-up to 3.3V on that SSR side to signal a state to the Prop.
But a schematic and product number would be good in case what you are doing is misunderstand.
Duane J
Does this mean that the switch portion of the device is connected to the prop? If that is the case then most likely one side would go to the prop pin/pulldown resistor and the other side to +3.3V so the pin goes high when the switch is closed.
The motion sensors I work with have a mechanical relay with Common/Normally Open/Normally Closed contacts so you can select either a closed or an open contact to indicate motion.
It is a little unusual for a Motion detector to source 5V, if you are providing that 5V, consider providing 3.3V, or simply switching to ground.
The most common circuit is something like a 10k pullup, and a 10 k series ESD resistor, and the switch connects to GND.
Some designs use ~470R in series with GND, to again reduce ESD effects. Depends how long the wires are to the sensor.
If the sensor does source 5V/1K., you could consider your own opto coupler at the Prop end, for highest immunity.
You definitely DO NOT want to put 5V on a propeller pin via a 1K resistor. That will most likely damage the prop. Use a 3.3K resistor to limit the current to a safe level.
