Can you use different size fonts at the same time on Ray's PSB?
I've been playing with Ray's PSB_8x8_Test code and making some menus. Is it possible to mix in a larger font so I can have some lines in the 8x8 style and some in the larger standard VGA style? I don't know what the larger font is called but it is the standard larger sized font in some of his other demos.
Or is there an object already that has some mixed size fonts?
Thanks.
Don
Thanks.
Don
But, that would take some work with the assembly driver...
Might be easier to use Graphics.spin and the vector font over some portion of the screen...
I think you can pretty much copy and paste that line or lines of code into "PSB Paint" and do the same thing there.
