I'm interested I have a version of F32 that I'm getting ready to post that has a built in "interpreter" to do sequences of float operations at PASM speed without needing the Spin calling cog. However, it relies on the fact that all of the F32 commands are standardized, and don't have extra functionality outside of the PASM.
Fixing the PASM part of the code is currently by programming abilities. I don't think it would be hard to write this "patch" in PASM, but I don't think there is currently room left in the cog.
Here's my latest patch.
I added a few constants which I use in the patch code.
CON
ONE_ = 1.0
NEG_ONE = -1.0
ZERO = 0.0
PI_OVER_TWO = pi / 2.0
THREE_PI_OVER_TWO = (3.0 * pi) / 2.0
And here's my latest "ATan2" method.
PUB ATan2(a, b)
Arc Tangent of vector a, b (in radians, no division is performed, so b==0 is legal).
Parameters:
a 32-bit floating point value
b 32-bit floating point value
Returns: 32-bit floating point value (angle in radians)
if b == ZERO
if a == a & $7FFF_FFFF
return PI_OVER_TWO
else
return THREE_PI_OVER_TWO
result := b & $7FFF_FFFF ' absolute value
if b == result
b := ONE_
else
b := NEG_ONE
a := FDiv(a, result)
result := cmdATan2
f32_Cmd := @result
repeat
while f32_Cmd
It checks to see if the denominator, "b", is zero; if "b" is zero, it then sets the result to either "pi/2" or "3*pi/2" depending on the numerator's sign. Non-zero denominators are set to "1" or "-1" and the numerator is divided by the absolute value of the original denominator.
I don't know what values of "b" cause erroneous results, but I haven't seen any problems if the "b" value is limited to "-1", "1". I haven't tested zero "b" values to see if there are any "a" values that would cause a problem.
I've attached a modified F32 with the above patch.
For my needs, the trig functions of F32 are the most important aspect of the program. The inverse kinematics code I'm working on has a lot of ATan2 calls. I'm really hoping Jonathan or someone else who understands the code can fix this problem.
Duane: The F32 assembly code uses a cordic loop for Atan2 while Float32Full uses reverse table lookup. F32 *should* be more accurate, but it looks like something got messed up in the scaling? Note, Atan(x) is the same as Atan2(x, 1.0). It's likely only Atan(x) was tested, so this bug got missed.
Have you run the same numbers through Excel or a programming language? It'd be nice to confirm how good Float32Full is getting the calculation.
I've seen you out and about on the forum and I'm hoping your have time to take a look at the ATan2 issue. Let me know if there's anything I can do to help (hopefully something I know how to do). I could run some test numbers through the new method, when you're ready, if you like.
Thanks again for creating F32. I use it all the time.
Thank you very much for fixing this. Sorry for not testing earlier.
Something strange is going on in my test program. When I use the new version of F23 it crashes but if all the floats are done with Float32Full it doesn't crash.
Give me a bit to pin point the code causing the crash. I'll post the test code here once I find the exact F32 call causing the problem.
Edit: I'm starting to think the crash is caused by something unrelated to the floating point calculations. I'll post more once I'm sure.
My problems with the Prop apparently crashing was the result of my using the "DTR" check box to reset the Propeller. Once the "DTR" check box is used it stays active so when I'd press the space bar to trigger the next set of data to display it would be checking and unchecking "DTR". The second space bar press would cause the Propeller to reset. I need to remember the Parallax Serial Terminal has this feature.
Sweet! The issue was an overflow in the CORDIC routine. I had previously attempted to convert some other functions to use CORDIC, but was running into weird problems reusing the same code...might be related. If nobody has any problems, I will post this version to the OBEX, then proceed trying to CORDICify some other functions. [8^)
I'm hoping I can talk you into updating the OBEX version with your latest fix.
With the recent change in the OBEX old links to it have been broken, including the link in your signature. The OBEX search appears to be just about worthless so I always just display all the objects on a single page and use the browser's search feature to find the desired object. I did this to find F32's current location.
Whist we are here. I was recently playing with quaternians and found this magical piece of code for performing fast inverse square roots. That is 1 over the square root of x or x to the power minus one half. Trick is it uses integer math and a four floating point multiplies.
In C it looks like this:
float invSqrt(float x) {
float halfx = 0.5f * x;
float y = x;
long i = *(long*)&y;
i = 0x5f3759df - (i>>1);
y = *(float*)&i;
y = y * (1.5f - (halfx * y * y));
return y;
It occurred to me this might make a nice addition to F32 if there is any space left.
f32.sin(Constant(pi/2.0)) :1.000001e+0 ????
f32.Asin(1.000001) :6.805647e+38 that is the key
f32.Asin(1.0) :1.570796e+0
Can you please post your complete code here (archived)?
For me the binary pattern of sin(PI/2) says exactly 1.0 ($3F800000), not sure where you get that extra non-null digit from. As for arcsin(1.000001), what did you expect it to return?
The only thing missing is the odd 1.000001, other than that we just found a bug in FloatString although it can be argued that it was never designed to handle special numbers (like NaN). So everyone please relax.
Post [post=1295934]#114[/post] contains the archive showing the bug (6.8...e+38).
I for one wouldn't have worried much if the problem had been stated as Asin(1.000001) equals 6.8...e+38 since 1.00001 isn't a valid parameter to the Asin method.
I'm actively working on code for my hexapods and a bug in the Asin method would be a serious issue (as the bug in the Atan2 method had been). I was irritated to find I had spent time investigating an issue which didn't exist.
To clarify, yes it is an invalid parameter which causes NaN to be returned (but displayed wrongly, 3.4e+38 is max for float). What I'm still puzzled about is how the 1.000001 was produced in the first place.
ViewPort used to use the decimal representation of Pi given in the Propeller Manual which is very slightly different than the hex representation probably used by the Propeller Tool/BST. When I changed this, the result from the float object for sin(pi/2) is now the same as bst/propeller tool= 1.0
However, the following code now produces an error on all compilers because the float object has an error in it's sin/cos calculation:
The output is:
f32.sin(Constant(3*pi/2.0)) :-1.000001e+0
As pointed out by Magnetspin, this error may be tiny, but if used in subsequent calculations can result in NAN which is a pretty big number for our Prop.
Hanno
CON ONE_ = 1.0 NEG_ONE = -1.0 ZERO = 0.0 PI_OVER_TWO = pi / 2.0 THREE_PI_OVER_TWO = (3.0 * pi) / 2.0And here's my latest "ATan2" method.
PUB ATan2(a, b) {{ Arc Tangent of vector a, b (in radians, no division is performed, so b==0 is legal). Parameters: a 32-bit floating point value b 32-bit floating point value Returns: 32-bit floating point value (angle in radians) }} if b == ZERO if a == a & $7FFF_FFFF return PI_OVER_TWO else return THREE_PI_OVER_TWO result := b & $7FFF_FFFF ' absolute value if b == result b := ONE_ else b := NEG_ONE a := FDiv(a, result) result := cmdATan2 f32_Cmd := @result repeat while f32_CmdIt checks to see if the denominator, "b", is zero; if "b" is zero, it then sets the result to either "pi/2" or "3*pi/2" depending on the numerator's sign. Non-zero denominators are set to "1" or "-1" and the numerator is divided by the absolute value of the original denominator.
Lawson
I ran a bunch of the above numbers through Window's calculator and they match with Float32Full out to four decimal places.
I noticed that Atan uses Atan2. That's why I decided to test using one as the denominator with ATan2.
My brain is at capacity until a little after Christmas. I will review this stuff as soon as I have some time.
thanks,
Jonathan
I hope you had a nice Christmas. Any chance you'll have time to take a look at the ATan2 bug soon?
Duane
Jonathan
thanks,
Jonathan
Here's my test program:
CON _CLKMODE = XTAL1 + PLL16X _XINFREQ = 5_000_000 OBJ F32 : "F32" FloatFull : "Float32Full" Pst : "Parallax Serial Terminal" FloatStr : "FloatString" PUB Setup | localIndex Pst.Start(115200) F32.start FloatFull.start FloatStr.SetPrecision(4) MainLoop PUB MainLoop | index1, index2, result32 'Pst.str(string(13, "Start of MainLoop Method ")) index1 := 25.0 repeat index2 := 31.0 repeat 10 Pst.str(string(13, "Tan2(")) Pst.str(FloatStr.FloatToString(index2)) Pst.str(string(", ")) Pst.str(FloatStr.FloatToString(index1)) Pst.str(string(") | F32 = ")) result32 := F32.ATan2(index2, index1) Pst.str(FloatStr.FloatToString(result32)) Pst.str(string(") | Float32Full = ")) result := FloatFull.ATan2(index2, index1) Pst.str(FloatStr.FloatToString(result)) index2 := F32.FAdd(index2, 0.1) Pst.str(string(") | Difference = ")) result := F32.FSub(result32, result) Pst.str(FloatStr.FloatToString(result)) index1 := F32.FSub(index1, 0.1) Pst.charinHere's some of the output:
I used these test numbers since they were numbers which caused problems with the version 1.5 code.
Are there other sets of numbers anyone thinks would be worth checking?
Thanks again Jonathan for this recent fix and for F32. It's a great object.
thanks,
Jonathan
wtf? Fmod(2.0, 3.0) is 1073741824 according to F32 and Float32Full. (it should be 2.0)
Lawson
Edit: turns out I'm wrong and F32 is right. When you display Ffloat(2.0) as a decimal number 2.0 == 1073741824. :zombie:
Again, thanks for making such a useful object.
Jonathan
With f32.Asin( f32.Sin(Pi/2)) we get 6.805647e+38 instead of Pi/2.
Best Regards
Which language is that, Spin or C?
If it is Spin then the Pi / 2 will be done as integer arithmetic and give the wrong result.
Surely that should be f32.Asin(f32.Sin(f32.Div(Pi, 2.0))) or whatever divide is in F32, I forget.
float invSqrt(float x) { float halfx = 0.5f * x; float y = x; long i = *(long*)&y; i = 0x5f3759df - (i>>1); y = *(float*)&i; y = y * (1.5f - (halfx * y * y)); return y; }It occurred to me this might make a nice addition to F32 if there is any space left.You can read about this little code trick here: http://en.wikipedia.org/wiki/Fast_inverse_square_root It was first made public in the Quake III arena source code.
I was testing Jonathans F32 obex with these results:
f32.sin(Constant(pi/2.0)) :1.000000e+0 :thumb:
f32.Asin(f32.sin(Constant(pi/2.0))) :6.805647e+38 :frown:
Are you using the latest version of F32?
I can't repeat your results.
Can you post your test code?
I just added the code below to a program I'm presently working on which is using two instances of F32 (hence the "[PATH]" identifier).
F32[PATH].Start FloatStr.SetPrecision(4) Com.Strs(DEBUG_COM, string("result = F32.Sin(pi/2.0) = ")) result := F32[PATH].Sin(constant(pi/2.0)) Com.Str(DEBUG_COM, FloatStr.FloatToString(result)) NewLine Com.Str(DEBUG_COM, string("F32.ASin(1.0) = ")) Com.Str(DEBUG_COM, FloatStr.FloatToString(F32[PATH].ASin(1.0))) NewLine Com.Str(DEBUG_COM, string("F32.ASin(result) = ")) Com.Str(DEBUG_COM, FloatStr.FloatToString(F32[PATH].ASin(result))) NewLine Com.Str(DEBUG_COM, string("F32.ASin(F32.Sin(pi/2.0)) = ")) Com.Str(DEBUG_COM, FloatStr.FloatToString(F32[PATH].ASin(F32[PATH].Sin(constant(pi/2.0)))))Thanks for the input.
I have the latest version form obex.
I encreased the Precision of the output:
F32 testing
No idea, whats going on.
I am spinning...
Thank you for the help.
The actual result of the second line is correct, i.e. NaN which is returned as POSX. IOW FloatString somehow can't cope with it.
Where is the code which produced this error?
As kuroneko showed the code below produces the expected results.
Why make a false claim?
Edit: I apologize for my rudeness.
Since you requested it, I'll relax. But I'll still be bit irritated (but not for very long and it will be a relaxed state of irritation).
Time of a nice relaxing dinner.
The problem is solved now: Hanno found the error. His compiler used 3.141593, which equates to $40490FDC. He had to change this to $40490FDB.
Thank to all for the support.
F32.start
fs.SetPrecision(10)
F.start
vp.str( string(13, " f32.sin(Constant(3*pi/2.0)) :" ) )
vp.str( FS.FloatToScientific( f32.sin(Constant(3.0*PI/2.0))))
The output is:
Hanno
